sbelyo
- Jun 9, 2004
Pics...
Originally Posted by sbelyo Thanks.... I'll take a picture of the finished guts tomorrow. It got a bit tight in the front with the xlr, 2 power caps, and 4 output caps. But it's all in there. It's got a little hum, but not too bad. I'll ground the heaters with 2 100 Ohm 2 watt resistors and see if that helps. It's gonna need a cover, the 6AS7G gets hot enough that it may burn my little girl's fingers (she touches everything). I'd say all tolled my cost was $225 with shipping from 4 different vendors and 1 set of tubes off of ebay. But you could easily trim $40 buy using the open frame style hammonds and getting all the resistors and caps from mouser. But you'll need at the very least a step drill that goes to one inch and a cordless drill. |
Originally Posted by sbelyo Hum is now gone.. Just put a 100 Ohm 3 watt resistor on heach heater pin to ground |
Originally Posted by philodox I'll be watching this project closely. This amp bears a striking resemblance to one that I made which ultimately was a flop... though I think that this design is a bit more 'sane'. |
Originally Posted by Rescue Toaster Did you ground the center tap? And still had hum? |
Originally Posted by sbelyo Yeah... It wasn't really bad but it was annoying me. Actually the heater supply on the 269AX does not have a CT so maybe that's where it was coming from. I used that supply for the 6DJ8. This amp to me is sounding great. There is plenty of bass with my DT770's and the vocals are amazing. I noticed that the instruments sound more seperated. |
Originally Posted by philodox Sweet. I've got a friend who is building an Aikido [tubecad.com] and my plan is to wait until he is done so that I can have a listen. At that point I will decide between it and the bamaslama... and now this amp. |
Originally Posted by jbloudg20 I'll note the resistors to add to my heaters as well. |
Originally Posted by sbelyo I think the simplicity lends to it's nice sound. |
