My turntable acts like a tiny speaker...
May 21, 2007 at 2:24 AM Thread Starter Post #1 of 13
daggerlee
When I play vinyl, I can hear the music very tinnily being emitted from the turntable itself. I assume this is because it's not grounded properly? It's a 1970s Dual with the seperate grounding cable...
May 21, 2007 at 2:37 AM Post #2 of 13
I'm not an expert, but I'm pretty sure that's normal. My table does that as well, and it's grounded. When the table's not properly grounded, you will hear a very distinct, constant hum through your speakers/headphones that's not correlated to the music signal. I think the low-level sound you're hearing is the vibations from the needle/cartridge getting directly transduced into sound waves.
May 21, 2007 at 6:51 AM Post #4 of 13
infinitesymphony
What you're witnessing are the basics of how a turntable works. As the record spins, the needle travels over bumps in the grooves of the records, producing sound. The sound that you hear is also traveling through the cartridge, down the tonearm, and out of the RCA cables where it's amplified several times over by both a phono preamplifier and a preamplifier/amplifier. So, that quiet signal you're hearing is the music.
May 21, 2007 at 2:37 PM Post #6 of 13
Davesrose
you know the early phonographs didn't have any internal amplification, and didn't have speakers attached. They just had a horn attached to the needle! A record needle produces sound "mechanical energy". In the early days, that mechanical energy would just be amplified by a horn. With hi-fi turntables, that mechanical energy gets converted to electrical energy by the cartridge. Through magic, it eventually gets to your speakers
May 21, 2007 at 3:07 PM Post #7 of 13
memepool
Spot on.
Many 78 aficionados argue about whether 'acoustic' grammophones are better than 'electric' ones, steel needles are better than thorns etc etc...like some of you guys argue about DACs.
If you ever get to hear a large acoustic grammophone it's something quite special, the aural equivalent of seeing a ghost.
May 21, 2007 at 3:43 PM Post #8 of 13
Cool, so my instincts were right
When I first heard the "music" playing from the cart with no speakers/headphone hooked up, I was freaked out - then I though about it for a minute and realized that the needle/cart itself was acting like a tiny speaker
May 21, 2007 at 4:40 PM Post #9 of 13
robm321
Yeah, it's pretty cool - actual analog sound
May 22, 2007 at 5:06 PM Post #10 of 13
GlendaleViper
Yep, words.
Heheheh. I discovered this as a kid when (much to my dad's chagrin) I decided to manually spin our record player unplugged. I'm sure the simplicity of the vinyl medium's mechanism is what gives it that natural tone.
May 29, 2007 at 4:23 AM Post #12 of 13
Sinwerm
This is a cool thread !! Im a digital guy (now) but I remember as a kid putting my ear very close to the turntable and hearing that tinny high sound emitting. Made me think wow they really captured each sound of live music vibrations and cut/pressed them into a record. So pure , I miss that sometimes ... maybe someday again.
