My new SinglePower SDS amplifier
Oct 19, 2004 at 1:56 AM Thread Starter Post #1 of 76
mikeg
My new SinglePower Supra SDS amplifier was delivered today in a large wooden crate that weighed 75 pounds. It took me over an hour, and use of an electric screw driver, to pry this beautiful amp. out of its crate, and to separate it from loads and loads of bubble wrap. Mikhail did a phenomenal wrapping and crating job in order to assure the safe arrival this top-of-the-line SinglePower amp, which weighs 31 pounds. I took detailed pictures of the uncrating job, for those who are interested, and I'll display them next week.
I then proceeded to connect the SDS amp. to a Marantz CD5000 CDP, and to power it through a Monster Power Center PC1000 power conditioner. I did my first listening to, and checking out of the amp. using R10, HD650, and RS-1 headphones. I also did a quick, though rather silly, comparison of the SDS to an RA-1 amp. Use of this Marantz CDP is only temporary, since I'll receive an Exemplar Audio (i.e., John Tucker) modded Denon 2900 universal player tomorrow. My final system will thus consist of the R10 connected to the SDS, and fed by the modded Denon. Features of the SDS include two inputs, two preamplification outputs, one pass through input/output, and a Shallco 45 position stepped attenuator.
Here are my first observations, which are based on about one hour of listening to a Buena Vista Social Club CD. The SDS sound is phenomenal when connected directly to an electric outlet, especially when listening through the R10. Clear and sparkling mids and highs, deep, deep base, broad sound stage, and great separation and sharp focus of instruments. But, when connected to the Monster power conditioner there was a substantial loss in sound quality. The power conditioner caused the sound to lose some of its sparkle, clarity, and resolution; i.e., the result was a kind of warm and somewhat syrupy sound. The Monster PC1000 power conditioner definitely diminished the fantastic sound quality of the SDS amp. I think that the solution is either to connect the SDS amp. directly to the wall power outlet, or to a high quality surge protector, but not to a power conditioner. I'll also consider substituting a high quality power cord for the computer power cord that's now conneced to the SDS. I also tested all of the inputs, outputs, and pass through, and confirmed that they work fine. As for the 45 position stepped attenuator, it's wonderful; i.e., very fine control over the volume. I also turned the attenuator to max without any input signal, and the result was dead silence.
When listening to the R10, HD650, and RS-1 through the SDS, the R10 sounded glorious. All of my above listed descriptors applied in full measure. The HD650 also yielded a full and rich sound, but a bit too heavy for my taste. As for the RS-1 it sounded wonderful; i.e., IMO it came in between the R10 and HD650. The RS-1 delivered a bright, detailed, and lively sound, with deep and detailed base. So, my order of preference was: R10, RS-1, and HD650. I believe, however, that Mikhail optimized the SDS for the R10. I also connected the RA-1 to the pass through output, and connected the RS-1 to it. The sound was beautiful, but lacked the broad sound stage, and focussed placement of instruments that's provided by the SDS.
Well, these are my observations from the approx. first hour of listening to my new SDS amp. Additional comments, and some pictures will follow next week, although I don't plan to wait for any burn-in period. I'll let the SDS condition (i.e., burn-in) just by listening to it. However, even without any burn-in, this SinglePower SDS amplifier delivers outstanding sound.
Oct 19, 2004 at 2:07 AM Post #3 of 76
Congrats Mike! That should be quite an amp, I look forward to hearing more detailed listening impressions and of course the pics.
Oct 19, 2004 at 2:16 AM Post #4 of 76
Congrats. I can't wait to see the pic's.
Oct 19, 2004 at 3:03 AM Post #8 of 76
Originally Posted by GoRedwings19
Is it possible for mikhail to tune the amp to any headphone or is it more general like senn sound or grado sound?????
I really don't know the answer to this question. Best to call Mikhail directly. His number is 303-523-0581. BTW, hirsch may also be able to answer this question.
Oct 19, 2004 at 3:21 AM Post #9 of 76
congrats on the new amp mikeg.
a 75 lbs. shipment weight for a 31 lbs. amp? that's quite excessive.
is the 45 point stepped attenuator a worthwhile feature to have? I went with the traditional 24 point stepped attenuators thinking that I can do finer adjustments with the digital volume control on my source... but I've been going back and forth on that issue. what are your thoughts on that?
Oct 19, 2004 at 3:40 AM Post #10 of 76
Congrats on the new amp! Mine is even better than I had hoped for. It breathes life into the R10 like nothing else I've heard.
Mikhail can tune the amp to a particular sound, but it's easier to tune it by choosing a set of tubes that sounds right to you. I'm enjoying a Ken-Rad VT-231 in front of a pair of Tung Sol roundplates. Once that combo settled in, I've simply left it alone. I ran out of reasons to change tubes
Oh yeah, there's a phenomenon I've noticed with Mikhail's amps. They take much longer to burn-in than you'd expect. I suspect the large caps take a long time to form. When it's there, the change is not subtle. The whole sound turns much more transparent (If it isn't already gotten there before you get the amp). You'll know it if you hear it...
Oct 19, 2004 at 4:08 AM Post #11 of 76
He he
I wonder if mikeg's car or the UPS/FedEX truck tipped over
You can use the 24 point stepped attenuator along with a gain switch for finer adjustment - almost as good as 45 point...
You can use a 45 point stepped attenuator along with a gain switch for incredible control over the volume levels
Oct 19, 2004 at 4:10 AM Post #12 of 76
Mike, if you want power protection that doesnt screw up the sound get a PS Audio ultimate outlet(UO). You will need a good power cord from the UO to the wall for best results. I have a used PS Audio original lab cable I picked up off audiogon that I use. I like the amps best straight out of the wall too but after a lightning strike destroyed one on my mpx3's and all the electronics in the computer room and back bedroom I have them on the UO's. The UO requires you retune the amp a little with different tubes but once you do you will be satisfied. The UO's seem to cause very little sound quality loss once you reoptimize the tube set. With the weather you have had down in Florida lately I would be careful. Congratulations and enjoy the amp.
Oct 19, 2004 at 4:19 AM Post #13 of 76
that doesn't help, but is making the decision more difficult.
how good is this 45 point SA compared to the goldpoint SA? the gain switch sounds like a good idea, but that will be another item in the circuit, which might be better left off... I haven't seen any singlepower amps come with a gain switch either (it that means anything).
Oct 19, 2004 at 4:30 AM Post #14 of 76
I would pick the 45 point SA over the 24 step goldpoint and a gain switch myself. The gain switch/goldpoint costs less but complicates the circuit. I am not a big fan of stepped attenuators once I used them at length. Its to hard to get the volume just right. I am getting the TKD pot on my next amp. Stepped attenuators have amazing resolution but I cant take the volume being slightly to high or low.
Oct 19, 2004 at 4:37 AM Post #15 of 76
Congratulations on purchasing an outstanding product from one of the good guys. I wish you many, many years of enjoyment from it. Of course, thats until you upgrade to something else from Mikhail one day and join Team Ramen where most of us find ourselves at times.
JC
