jaibautista
- Apr 21, 2008
mvw2,
I am also sitting on the fence regarding getting a pair of IE8s. Although I still am far from saving up the amount to get a pair, I'm already choosing between the UM3x and the IE8. Right now, as I'm typing this, I'm listening to my TF10s. Although I really haven't had the opportunity to test this against other high-end universals, all I can say is I fully concur with what you've said about the TF10s: yes, they are very, very balanced (although the mids are somewhat recessed, which works for me for a non-fatiguing listening experience and to give that impression of an even wider soundstage than it impresses at first glance) and the treble is to die for. When I listen to recordings that are heavy on cymbals, I can't help but stare at the distance...as if I'm lost in a transient haze. What's more impressive about the high frequency extension is that it hangs magically...and extends beyond your expectations.
If you're coming from the TF10s and you plan to perform a sidegrade, which is the more logical path: going through the IE8 or through the UM3x?
Thanks a lot!
Originally Posted by mvw2 /img/forum/go_quote.gif I can give my take on them... Completely different focuses really but both really quite good. Both offer a sizable sound stage (relative to the other options). The TF10 focuses on the top end while the IE8 focuses on the low end. Both are largely well balanced in response with the IE8 having a slight bump around 100Hz and the TF10 a bump above 10kHz. The TF10 does roll off under 100Hz though. The IE8's bass is visceral. The TF10's treble is endless. I personally consider the IE8 to be slightly soft on detail. I also consider the TF10 to be slightly constrained on dynamics. I say these things relative to other products on the market. The IE8 is pleasant, natural, and visceral. A touch of EQing can cut down the midbass bump if desired. If I could change one thing with the IE8 it would be a little more edge/detail, personal preference really. If I could change one thing for the TF10 it would be a more extended bass response. It can get to 30Hz with a lot of EQing, but it'd be better if it could do it on its own. There isn't another IEM on the market that is as balanced and visceral as the IE8. There isn't another IEM on the market that is as balanced and refined as the TF10. ...all in my opinion of course. |
mvw2,
Thanks a lot!
