chinsettawong
The “fart” is actually the sound of the diaphragm hitting one of the stators. Since the diaphragm is sitting in the middle of the two stators with only 0.5 mm of clearance on each side, any sudden change in pressure in the headphone’s enclosure can push the diaphragm to hit one of the stators. If the tension is high enough, after hitting the stator, the diaphragm bounces back to the middle where it should be. If the diaphragm tension isn’t strong enough, the diaphragm can stuck on the stator and would only bounce back when you discharge it.
As far as I have experienced, Stax headphones’ diaphragms are tension high enough and the diaphragms bounce back. This phenomenon is quite common no matter they’re DIY or commercial headphones and it should not do any harm.
