MX500 volume control ...
post-184443
Thread Starter
Post #1 of 9
akerman
what's up with it? I just got a pair yesterday, and I already broke one of the little foamy things because they were so hard getting on - where can I buy a replacement?
and also, is the volume control supposed to be next to useless? If I put it all the way to minimum, the sound volume is still at a normal listening-level - e.g. the difference between MIN and MAX is not a whole lot with my specimen, is this the way it's supposed to be?
as a positive note, the sound quality seems impeccable though =)
post-184446
Post #2 of 9
andrzejpw
May one day invent Bose-cancelling headphones.
You can buy replacement pads at radio shack.
The volume control doesn't really make that much of a difference. . . I mean, its not like mute. . .
post-184450
Post #3 of 9
akerman
well i sincerely doubt we have radio shack in denmark=)
post-184455
Post #4 of 9
Braver
Will upgrade headphoneswhen there's a MX600.
you should have some electronics-parts-store even in Denmark. y'know, where they sell all sorts of cables, cartridges, connectors, maintenance stuff, spare parts etc etc. usually in the larger towns.
post-184464
Post #5 of 9
JMT
JMT Audio:PPA/META42 Amp Factory
Moderator
....the "volume control" is a joke.
post-184481
Post #6 of 9
lextek
I use it has a mute switch.
post-184496
Post #7 of 9
jpelg
Needs a regular fix of 'Fi
'06 Nat Meet Co-Coordinator
The Elm City
The Elm City
Hmmm. The sliding in-line volume control on my Sony 821's completely mutes the sound when turned all the way down, too.
Maybe something wrong with your Senn's?
post-184539
Post #8 of 9
taoster
my volume control also works as advertised.. sounds like you got a defective unit?
post-184570
Post #9 of 9
Mystyler
My MX500 volume control works perfectly - except from a bit of static.
