mmerrill99
Member of the Trade: M2 Tech
- Mar 2, 2006
Ok, I didn't think it was difficult to plug the two together & give a quick review but maybe it is? So how does it sound with the MSB?
Originally Posted by jkeny /img/forum/go_quote.gif Ok, I didn't think it was difficult to plug the two together & give a quick review but maybe it is? So how does it sound with the MSB? |
Originally Posted by Budley007 /img/forum/go_quote.gif Have you tried a USB cable with the extra power connector? One of my external hard drives comes with a cable like this. ![]() |
Originally Posted by some1x /img/forum/go_quote.gif For what its worth, it had less pop problems on my laptop. I just got the MSB a couple of days ago. It already sounds very good with my motherboard's digital out. The Monitor 01 may sound better, but the pop issue is an absolute deal killer. |
Originally Posted by some1x /img/forum/go_quote.gif Dunno if I can actually find a cable like that... and it would need to have the larger connection "square" on the device-end. Love the Avatar, btw ![]() |
Originally Posted by Kpalsm /img/forum/go_quote.gif Perhaps you just got a bad unit, it happens. Try e-mailing the seller and see if you can get an exchange going. Also, I recommend this USB hub, I use two of them and have everything I use plugged into them, including: keyboard, mouse, usb mic, ipod sync cable, 1TB external HDD, Xbox wireless controller adapter, etc. and all of it works perfectly. It's a Multi-TT hub, which if you're unfamiliar, means that opposed to a single-TT hub, each USB port has it's own data controller meaning each USB port gets full bandwidth capabilities, rather than having one port's shared bandwidth (more useful for having a usb 1.1 device and a usb 2.0 device connected, a single-TT hub would bring the speed down to 1.1 for the 2.0 device). 7 Port USB 2.0 HUB w/ AC adapter - Monoprice.com |
Originally Posted by DoYouRight /img/forum/go_quote.gif It might very well take a month or so to get it out, remember they are programming the chip for 24/192 usb. Not an easy task or every dac company would do it. |
Originally Posted by tosehee /img/forum/go_quote.gif Yeah. I understand. I was just wondering if there is a page where I can periodically check for updates and such. Or even register to get notification or similar. |
