T 1000
I really don't care whose is bigger and nicer, I have a great synergy that will soon be upgraded with a curious usb cable and a better xlr cable.I just have to get this off my chest... How can you NOT own a Denafrips Terminator??? I mean T1000?
As far as I know all those 3 reviews follow the exact same lines of the press release. Exactly telling us as instructed. Same phrases, same words. So much for independent journalism. The only one who does not follow the official party line is critical.
You ASSUME the device sent to NBT is faulty. I sincerely doubt it. As i explained elsewhere the probable cause is the computer + s/p-dif. S/p-dif has one line sending alternating packages of left and right signals, so messing up the timing can make it swap sides. It could be the s/p-dif receiver is causing these timing issues, but if it's 'allergic' to vague timing i wouldn't nescessarily call it faulty. Just feed it better signal and its fine.
One other thing i can think of is the extra inputs. Iirc these splice in after the s/p-dif input. Could that be the cause? That they made a shortcut and left the door open for RF noise or something?
I think it's telling that 'Musician' support and testers have no clue and just send customers a test chart saying 'the unit is fine, it is your fault'. This is what happens when you steal a design and sell it off as your own. When you designed something yourself you have a far better grasp of what might be going wrong (and a clear conscience, no need to cover up).
Also again you assume Musician audio sent the unit 'to the reviewer who has already declared himself against Pegasus!'. Where did you get that? Jay comes across as very, very objective, fair and super honest. When fed USB the unit works fine and this is what Jay from NBT reviewed and describes.
Jay is also honest enough to talk about the elephant in the room that all those other 'positive' reviews are silent as the grave about. That is that the Pegasus looks identical to the Denafrips Ares with cosmetic upgrades, extra inputs, downgrade in the power supply and a 'verschlimbessertes' (great german word for driving your cart in the muck while trying to improve) active output.
Maybe you are all hoping he had a defective unit that would explain the bad review. That way you did not make a wrong choice (who wants to admit that?) or could have done better at a lower price buying the Ares II. Well then rest assured, you still have a great dac that is far ahead of most of the competition. Most, because the original is even better AND cheaper to boot.
I currently enjoy running Adani & Wolf, and I know I didn't make a mistake in choosing any component in my system
