Audiobliss2
From the layout of the PCB, it looks like the two front tubes are the output tubes feeding the caps, and the back one is gain, is that correct?
The one on the PCB motherboard. What threw me off is the fact that all 4 tubes turned on fine, and the left channel was fine at low volume. I did a continuity test everywhere but the fuse.I thought of that , but felt for sure you had checked that. Anyway, good to hear it's fine.
Which one was blown, the one on the pcb, or the main.
Correct, the front two are the pre-amp tubes, the third is the gain.From the layout of the PCB, it looks like the two front tubes are the output tubes feeding the caps, and the back one is gain, is that correct?
I've got mine on 4 Isoacoustics Orea Indigo. They don't mount to the device, so I've not bothered with removing the stock feet yet.Changed the feet. The other setup made the preamp prone to tilting in the rear.
I was pleasantly surprised to see that treaded holes were provided in the rear, although it came with just the one spike foot in the rear.
That rear one is sealed tight not to be removed it seems.
That's a big tube, it must light up the room. You definitely need a top shelf for that.My two favorite tube combinations are Philips E80CC SQ with a Brimar 12AU7 as cathode follower and Sylvania 12SN7 Bad Boys with a GE 12SN7 as cathode follower. As caps I'm running Mundorf supreme aluminium oil 2.2. . Rectifier is a Emission Labs 274B mesh. Very happy with how it sounds.
There are not much difference between the Gold Lion 6922s and the Voshkod 6H23s, I love both. They are very similar sounding. Extended clarity, sweet mid-range, and huge sound stage. However, the 6H23s provide slightly bit deeper lows, while the 6922s provide slightly bit higher, more shimmering highs.So how are the Gold Lions 6922s doing ? Are they keepers. I thought I had a set but they are 12ax7s I had used in my last McIntosh preamp.
I also have a bunch of 5u4g , but they are just too tall for where I am using the preamp. I have some smaller 5u4gb, but from what I remember trying them in my other amps, they were very strong in the bass, which I also don't need.
I really like what you've done with this.How did you get the signal tubes to be so much more visible?My two favorite tube combinations are Philips E80CC SQ with a Brimar 12AU7 as cathode follower and Sylvania 12SN7 Bad Boys with a GE 12SN7 as cathode follower. As caps I'm running Mundorf supreme aluminium oil 2.2. . Rectifier is a Emission Labs 274B mesh. Very happy with how it sounds.
Thanks. I'm using 6sn7 -> 6922 adapters (adapters on ebay) to go from 8 pin octal to 9 pin of the pre. This lifts the sockets. The adapter also work at 12v with my 12sn7 sylvania bad boys that i'm currently running.I really like what you've done with this.How did you get the signal tubes to be so much more visible?
Thanks for the reply.Will definitely look for those.Thanks. I'm using 6sn7 -> 6922 adapters (adapters on ebay) to go from 8 pin octal to 9 pin of the pre. This lifts the sockets. The adapter also work at 12v with my 12sn7 sylvania bad boys that i'm currently running.
