bigshot
Pinnahertz mentioned they used a sync pulse generator to get the machines to run at a crystal locked speed. That's how film sync worked with Nagras back in the pre-digital days. They would have been most concerned with pitch, not phase, so they would probably slip start them with a start mark and probably lineup beeps (another film sound technique.) In theory, they could stack up as many tracks as they had four track machines with crystal lock. Abbey Road did a lot of film work, so I would bet they had access to as many as they wanted. The only limitation would be that it would all have to be done on the fly- no automation.
Back when I started in the film business, everything was on 35mm mag stripe. Editors would create separate sound reels with start marks for dialogue and effects (at least 2 overlapping rolls of each), a reel of ambiences (sometimes these were loops), and the music would be on a full coat reel that was capable of 3 tracks. So even the simplest film mix had six mag machines and seven tracks to work with. For big budget movies there could be a lot more with multi-tracked music and full coats for stereo ambiences and stereo sound effects. Dub stages would have banks of mag machines all crystal locked and lined up with start marks on the head of the reel. I can see where George Martin got the idea. He wouldn't have sprockets, so he would have had to line up manually each time he did a take and he wouldn't be able to jump around in the reel, but it would be possible.
All of the elements on Beatles sessions were logged and archived. It all survives. By this time they didn't need to be cheap with tape stock or studio time. All of this info is googleable. There have been a lot of articles on the reconstruction of the mixes in the past few months. They're doing several different kinds of mixes... some that reproduce the original mono mix just cleaner, some that open the mono mix up into stereo and make the balances closer to the Beatles' own mix (the original stereo mix was done by assistants), and the 5.1 mix which is intended to be an entirely new approach. Along with the blu-ray is a set of CDs that include outtakes, demos and mix elements broken out so you can hear how it was tracked. There is a hardback book that details the whole story of the sessions too.
I think when you get a blu-ray player you'll find that multichannel music has moved on a bit from the last time you checked it out. Movies tend to be less innovative, but that's to be expected because the sound is designed to reinforce what's on the screen, not create its own perspective. Immersive dimensional sound fields are the direction things are going in music. It's different than the typical front soundstage with reverb in the rears, and it's different than the ping pong approach too. It does takes a very carefully balanced system to pull off immersive sound fields, but there are audiophiles who have upgraded their home theater systems and calibrated them to work well with music as well.
