Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
647 648 649 650 651 652 653 654 655 656
658 659 660 661 662 663 664 665 666 667
  1. TheMarkRemains
    I think we need more clarification. In my definition your requests seem to be at odds. Intimate and soundstage seem to reflect opposite terms.an Hf5 is "intimate", a monster copper perhaps less so, the Westone 'W' series and Earsonics have more 'soundstage', then there's ie8 and SM64. I think you need to decide what it is exactly you're looking for.
  2. jant71
    To me soundstage has no quantifier/qualifier on it's own. An intimate soundstage is certainly available. I think the person needs to clarify their term "good soundstage". Intimate, deep, wide, tall, airy, etc. are fine basic descriptors but "good", not so much [​IMG].
  3. kylezo
    That's definitely a legitimate point. I find that, at least in comparison to other IEM's I've owned, the FXT90 has both a larger soundstage/better imaging and separation, AND more intimate feel of the mids (vocals/strings). I think this may be a more direct result of the sound signature of what I'm comparing with, however. To me, a "good" soundstage involves nice separation, imaging/placement, and an "out-of-the-head" feel. This, combined with the kind of musical presentation the FXT90 signature has, creates both intimacy and good imaging.
    Read what I said above re: soundstage/intimacy, however, it's true that I don't really know what I'm looking for. I mean, that's why I'm asking, haha. I'm considering just getting a "warmer" sounding IEM with a well-regarded soundstage; for instance, I've heard it said that the GR07 is on the "warmer" end of the spectrum for still being an "anaytical" IEM, so this may be what I'm looking for. With the recent mkii release, the prices on the older ones are coming down a bit as well, which may make a decision even easier to make :p
  4. ljokerl Contributor
    I agree with jant - "good" soundstage is a bit general - but I understand what you mean in this case. The FXT90 has good depth/layering and what I sometimes call a "strong center image", meaning it can center things on its soundstage very well instead of doing the left blob - right blob thing. Earsonics sets tend to be very good at this but they may not have the signature you want. The Westone UM3X is very good at this kind of presentation as well.
  5. herng
    Get my vsonic gr02.but with not much eartipis like promised, according to the retailers, VSONIC cut down the quantity cause of bad manufacturing.
  6. egosumlux
    Have you ever tested/auditioned the Vsonic GR04 pro's?
  7. ljokerl Contributor
    Hmm.. that's definitely too bad. Maybe the colors proved difficult. What tips does it come with now?
    I have not
  8. herng
    just 3 normal hybrids and one double flange. that all.
  9. Chubby-sama
    joker, can you recommend an iem with the best build quality for under $40? i'm not too particular about the other qualities, as long as they perform decently. thanks!
  10. ljokerl Contributor
    Hmm.. all black in color?
    The Philips "The Tread" is probably as good as it gets - it was designed from the ground up to be indestructible. Sound is okay - you can get better for less money but not with the same level of construction quality. If you're going to prioritize sound over build, I'd go for the RHA MA-350 or Dunu Trident. Both sound better than the Philips and are almost as well-made.
  11. Letchy
    Hello Joker, thank you for this informative thread!
    I am stuck between two IEM choices at the moment... I am looking at the MEElectronics M6 and the MEElectronics M9. They both seem to be pretty similar in terms of sound, however the M9s are relatively cheaper than the M6 model. One key factor in my choice is that I will be using these IEMs most of the time, while at College or running/working out... I notice both can be worn over the ear which is a good option for sporty activities, but I am unsure.
    If you could provide some extra insight and aid me in choosing, that would be awesome!
    Thank you!
  12. ljokerl Contributor
    The M9 can be worn over the ear but it's not nearly as secure when worn that way as the M6. For sports use there's really no competition - I still use my M6 sometimes when I need the secure fit.
  13. Impulse
    Have newer M6 revs changed anything significant? I noticed it says rev 1/3 on your profile, not sure if the refresh at the start of this year is #3 or what... I guess rev 2 was when they went to the less microphonic cable and hockey stick plug? That's the one I've got, it's held up well and I run with it a lot.
  14. ljokerl Contributor
    Nothing significant as far as I can tell - my newer one has a standard L-shaped plug, though. I've had this one since 2011. The rev.1 I have is an old maroon one with a straight plug and noisy cable.
  15. Impulse
    Hmm, think they've had like four different build revisions then (including this year's, or did only the M9 get a refresh announcement at CES? I forget).
