Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
632 633 634 635 636 637 638 639 640 641
643 644 645 646 647 648 649 650 651 652
  1. 23t23dS
    Really nice review on the VC02, they sound absolutely fantastic for the price.
    Short question though, did you reverse the polarity on them?
  2. papijoe08
    I forgot to ask that too :) +1 with that :)
  3. RollerBall
    Quick question regarding microphonics on the VC02, can you just clarify how bad it is when worn straight down? I straight up can't wear over the ear headphones so it rules out a lot of the stand out IEMs at the 30-60 price range. I'm used to wearing a J-Corded set so I get almost no microphonics at the moment.
    They'll be used to commute so I'll be walking around a reasonable amount in them (transfers between tubes) and audible (to the point where the interfere with music) microphonics would drive me up the wall.
  4. djvkool
    Nice review on the VC02, I can sense people are flocking to LMUE's site and purchase...[​IMG]
  5. tinphamhuu0212
    Can you review the The Brainwavz R1 , I'm very curios how they compare to the 30-60$ Vsonic headphones
  6. Zelda
    Nice review on the VC02.
    how is the clarity compared with the FX40 and RE0 ?
  7. kova4a
    NIce review on the VC02 - pretty much how I would rate it. I still think the GR04 flagship is superior but the VC02 is definitely on par with the GR06 with a different sound to suite the different people. I don't think it can replace any of the current vsonic line-up but it's a great addition to it.
  8. jarrett
    While we're on that topic...GR06 versus VC02? Can someone remind me what lendmeurears facebook coupon code is...the one that gives 5% off all the time...Thanks
  9. kova4a
    LMUECUST It's 15% on all items that aren't currently discounted. It should probably still work
  10. thesuperguy
    I am really sorry to be that guy, but I just can't help but notice that when you mention that the cables come off easily in your "cons" list for the VC02, you say "can come off to easily" instead of "can come off too easily. :p
  11. ljokerl Contributor
    I prefer the VC02 to the GR06 but only because it suits my preferred signature better. It is very difficult to split them on performance IMO.
    Burn-in was the usual 100-150 hours like all of the IEMs in this review. I did not bother listening to it before burn-in but I usually don't hear much change.
    I did not - with how easy it is to reverse polarity on these you'd think VSonic left it as is intentionally, either for tuning reasons or because it doesn't matter.
    I would say borderline. Wearing them over-the-ear is annoying for me because of the lack of a cinch so I always wear them cable-down. The cable is smooth and doesn't bounce around a lot. If you're going to move around all the time I would probably look for something quieter.
    They are so cheap that I don't feel bad about it [​IMG]
    I'll try to do so later but don't have a pair on hand so it'll be some number of months.
    Better than FX40 and just behind the RE-ZERO (don't have the RE0 anymore). On some tracks it keeps up with the ZERO and on others the ZERO sounds just a touch cleaner and less congested.
    [​IMG]
    GR06: bassier, warmer, thicker, fuller, may sound more natural depending on track, larger presentation (depth/height)
    VC02: clearer, more detailed, more balanced, thinner-sounding, cooler tone, tighter bass but also less body and presence
    I actually appreciate that - I was in a rush to get it posted on Sunday and didn't do my usual once-over after posting.
  12. meltie
    The 3A group including the VSonic is completely gone. Just mentioning it in case you hadn't noticed.
  13. Love Music
    Joker,
    would the Westone 4 or the BA200 fit my requirements also?
  14. Love Music
    Joker,
  15. Impulse
    It's also mentioned on the first line of the post for the Vsonic review. Broken posts are indeed broken... :p
