Multi-IEM Review - 352 IEMs compared (Pump Audio Earphones added 04/03/16 p. 1106)
Oct 12, 2010 at 2:09 AM Post #886 of 16,915
ljokerl
Portables Reviewerus Prolificus
This truly needs to be stickied. I've looked at this thread a long time ago and is the reason why I got the DBA-02's. I still look at today just to check out new IEM's.
It will be 100% perfect when the MC5, SM3, Westone 3's, Shure models, and UE Triple.Fi.'s get reviewed.
If you're specifically looking for it this thread shouldn't be hard to find - it's the first google search result for 'multi IEM review' or 'IEM review thread' or 'x IEMs compared' (where 0 < x < 115)
. Of that list Shure IEMs are the only ones I have no plans to review. Everything else is currently in progress.
Indeed. Hope there is a Westone 2 review as well. Can I audition your DBAs bai?
Yes, there will be a Westone 2 review
. Any earphone that is on the 'to do' list in post #8 is already in my possession and (most likely) is gathering dust awaiting its turn.
Will you look at adding the Sunrise SW-Xcape one day?
Yes, I have a couple of possibilities for getting a go at the Xcape. Hopefully I'll have my hands on it sooner rather than later but not too soon as I've got loads of other write-ups to post.
Oct 12, 2010 at 6:21 AM Post #887 of 16,915
DervishD
Thanks ljokerl, for the additions.
I think, too, that this thread should be sticky, I find it just imprescindible even in the (strange) occasions where I don't think the same as you in some model. I don't think anybody can find a more comprehensive and plain good list of IEMs in the net.
THANKS, dude
Oct 12, 2010 at 12:01 PM Post #888 of 16,915
JoetheArachnid
Amusing, since searching Head-Fi it's actually incredibly difficult to find. I am totally down with all the sticky sentiments - maybe it would lessen the number of 'Help - first time poster needs earphones!' threads.
Oct 12, 2010 at 2:51 PM Post #889 of 16,915
bisayaboi
Fantastic but why no Shure reviews?
Oct 12, 2010 at 5:35 PM Post #892 of 16,915
zachgraz
Vienna - Austria
@ Joker: great Fischer Audio Silver Bullet review.
I have received mine today from Russia. They really sounded amazing from the start. As you wrote in your review the cables are very thin above the y-split.
I always worry about breaking them. Like this the SBs do not look as if they were built to last...but the sound ... wow
Oct 12, 2010 at 8:05 PM Post #895 of 16,915
rawrster
i AM STILL waiting for bro joker's review on MILES DAVIS tribute...
I hope I'm interpreting this wrong but it does not look like you are being very appreciative of what joker has been doing. I wish there was some kind of guide such as this when I first got started in this hobby. It would have saved me a good amount of money (..maybe well probably not.) Writing reviews is not easy especially something such as this where there are lots of reviews. It takes a lot more time and effort that you may think if you have never written a review before. Also there are things other than reviewing that joker does so it's not like he can just pump out reviews like a machine.
Oct 12, 2010 at 10:22 PM Post #896 of 16,915
ljokerl
THANKS, dude
Thanks, D. Glad to see you around
Pretty much what rawrster said - I simply haven't had any pass through my hands since I started this thread and having some previous experience with lower Shure models I've never been tempted to buy any.
Fantastic thread!! Helped me choose my wonderful meelec m6's!
Thanks, glad the thread helped!
I say if you can get $68 worth of audio enjoyment out of them, it's still worth it in the end, but here's to hoping that the rev.2 is a better all-rounder
Thanks, rawrster, though I think his post came out sounding very different than was intended due to language barrier. Either way the MD review will be done when it's done
Oct 12, 2010 at 10:26 PM Post #897 of 16,915
mcnoiserdc
I don't believe pinoyman is being rude!
I think he meant like he can't wait for joker review of MD
THANKS, dude
Oct 12, 2010 at 11:04 PM Post #898 of 16,915
rawrster
I did leave the possibility of interpreting it wrong
If the rev.2 of the Silver Bullets has a much better cable and well a strain relief near the housing I might be tempted as long as sound isn't changed like what they supposedly did with v1 and v2 of the Eterna. It does depend on what earphones I have then but good deals always get me in the end ;p
