**MrSpeakers Mad Dog: Impressions and Discussion Thread**
Sep 18, 2013 at 4:50 PM Post #1,681 of 3,201
mikek200
Brooklyn,New York
  So you're saying no one makes a coiled cable that isn't $50+ and isn't complete **** with an L connector?
Try the used forums...or,
e-bay?
Like I said before----good luck
Sep 18, 2013 at 5:09 PM Post #1,682 of 3,201
Greed
  Don't want to have to dink with reterminating. I'm not that great and don't like doing that stuff. Would rather have one that already has the L connector on it.
$70+ isn't reasonably priced... I want a coiled cable for those times i do need to maneuver around my desk a bit and need the length but so I don't trip/roll over it/get it wrapped around chair when I am sitting right in front of PC.
$70 is pretty darn reasonable...
I think I've seen someone use a Beats coiled cable with the MD's. I think HiFiGuy has the cable, worth checking out. I'm not how much one of those cost though...
Sep 18, 2013 at 5:45 PM Post #1,683 of 3,201
kstuart
Good Luck..???
I've tried headphone extension cables that are less then $50, but were apparently good quality with good reviews, and they still deteriorate the sound quality.
So, a custom made cable by a guy who does headphone cables is the ideal option.  $75 is only 25% of the cost of the headphones (let alone the rest of the gear).
Sep 18, 2013 at 6:11 PM Post #1,684 of 3,201
mikek200
Brooklyn,New York
Thats what I did with BTG ,Brian matched my original cable to the extension cable
If memory serves me,the extension was something like $25.00
When I get my AD's..I will have to send them down to BTG again for him, to re-wire them again.
Sep 18, 2013 at 6:34 PM Post #1,685 of 3,201
MattTCG
I will have a pair hi-rose adapters for the AD so that I can continue to use my mini xlr cable with all my hp's.
Sep 18, 2013 at 8:16 PM Post #1,690 of 3,201
xilo
But I specifically need a coiled cable which they don't offer.
  V-Moda makes a coiled cable that will fit the MD's also
http://v-moda.com/coilpro-cable/
That could work with adding a right angle connector to the end so it doesn't stick out. Kind of dumb, but is best option so far...
Sep 18, 2013 at 8:33 PM Post #1,691 of 3,201
San Diego, CA
You should be able to just send him the cables to re-terminate.  The ADs are wired for balanced and single ended and the connector is really nice.  The pinouts are published on the website.
Dan Clark Audio Make every day a fun day filled with music and friendship! Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
@funCANS MrSpeakers https://danclarkaudio.com info@danclarkaudio.com
Sep 18, 2013 at 8:39 PM Post #1,692 of 3,201
gelocks
Other options:
http://shopworld.ultrasone.com/us/product.php?id_product=42
Or the Shure SRH cables but NONE of those have an L connection so you will always have to mod them...
http://www.amazon.com/Shure-HPACA1-Replacement-Headphone-Headphones/dp/B002Z9JWYO
or contact --> http://www.head-fi.org/t/658967/shure-srh-440-and-840-coiled-cable
Note that some of these have "locking mechanisms" for their respective headphones...
Sep 18, 2013 at 8:42 PM Post #1,693 of 3,201
gelocks
Orrrr...
http://www.amazon.com/Coiled-Stereo-Reinforced-Premium-Quality/dp/B004OL06IW/ref=sr_1_6?s=electronics&ie=UTF8&qid=1379551287&sr=1-6&keywords=coiled+cable+3.5mm
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=coiled%20cable%203.5mm
It seems some users don't like to use the search forms on web pages... ;-p
Sep 18, 2013 at 9:44 PM Post #1,694 of 3,201
Kamakahah
There really aren't a lot of options to fit the right angle entre on the headphone.
Almost all of them have to be filed, ground, or sanded to fit.
The Vmoda fits nicely but isn't coiled.
The one posted above might not fit.
You'll likely have to go the custom route to get exactly what you want. Maybe you can find a DIY member to make it for you cheaper but all the usual cable makers will do a great job otherwise.
Sep 18, 2013 at 9:51 PM Post #1,695 of 3,201
xilo
  Orrrr...
I saw those. Most are too short or need right angle adapter to not look weird. I was specifically asking for: one that already had angle connector and aren't completely **** without costing 1/3 the cost of the headphones.
