I find Ether and Ether C very comfortable. But just for giggles I thought I'd experiment with some alternatives for the headband.
Just noticed that you're selling your Ether C, any reason?
Ahh... OK. I'm debating myself that's why. I love the mids and highs, but man the lack of bass (at least to me) is not helping, although EQ did fixed that problem.
I find the comfort improved, and it was already very good. Not dramatically better, but nice.
^^ Sorry, no chance at all. Too much work and effort for a DIY project. Mr. Speakers Peter found a company on line that made a tooled leather headband that was drop dead gorgeous. Not sure what they charged for it.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
I'm in the same boat (although my Ether C is borrowed so I haven't actually spent any $$$ on it yet). Compared to my LCD-XC, straight out of the box it sounded extremely thin/hollow (almost like I was hearing sound through a pipe). EQ wise it takes +10 more dB to get bass similar to the XC out of the Ether C.
Having said that, after spending the time to EQ the Ether C properly (massive bass EQ, a couple bumps in the mid range, and a decent treble boost) it sound pretty good now. The bass is more controlled than the XC (although it feels like it has less "slam"/"impact", possibly just due to faster decay) and the soundstage is possibly wider on the Ether C (hard to tell due to the following negative) but it still sounds a bit thin/hollow to me. It might be the ~57mm (if you round out the rectangle) transducer vs the 106mm on the XC giving me the "pipe" illusion?
As has already been stated multiple times though, fit/finish/comfort on the Ether C is much better. It's much lighter, a much better fit, and I dig the look (never was a fan of the polyurethane wood look of the XC). Sound is what's important though and I'm still undecided there.
I honestly don't understand all the reviews saying the Ether C easily blows away all the competition in the price bracket though. I was extremely excited to try it out and was sure it'd knock my LCD-XC out of the park (as many reviews have said it would). Yet with no EQ I'd easily take my XC over it currently. Maybe I'm just lucky and snagged an XC with a good frequency response (yet another place Audeze seems to have issues, consistency). Some people will throw price out there, but you can buy the XC for around $1000 used (like I did) vs the current market price of $1300 for the Ether C (you can say the XC is $1200 with that new carbon fiber headband).
I still have a few more days with the Ether C. Hopefully it changes my mind as I really want to like it.
Hi... The XC would likely have more bass, that's the house sound. However, when I see +10dB, what I usually infer is there is a fit or system issue. On the fit side, you can verify the seal simply by having no music on and rubbing your fingertips together. If you can hear the rubbing your fit is off, PM me for an assist if needed. On the system side, once I saw a mis-wired XLR create a REALLY hollow sound, and another was Inthere's broken adaptor.
How can I check for mis-wired XLR? I guess it's time for me to get a cheap meter for continuity check.
