MrSpeakers Ether C Flow vs ZMF Eikons
post-15712738
Thread Starter
Post #1 of 15
Crazeenick
Morecambe
Morecambe
As well as open-back headphones (my main pair), I always have a high quality pair of closed-back headphones as well - which I can use when my wife is trying to watch TV in the same room - ie low sound leakage outwards is important. So Fostex TH900 are no good!
I currently have some ZMF Eikons which I do like, but would like something a little brighter in the treble end. Budget £1,000-£1,500 or so.
I was wondering about the MrSpeakers Ether C Flow? How do they sound compared to the Eikons? Are the Ether C Flows a bit brighter? Do the Ether C Flows have low sound leakage?
Any other good closed-back options in this price range?
Thanks.
post-15713051
Post #2 of 15
gimmeheadroom
Czech Republic
Czech Republic
Website
www.head-fi.org
post-15713073
Post #3 of 15
Monsterzero
Down at Dinos Bar & Grill
Have you tried swapping the pads?
The Verite closed has more energy in the upper mids,but its above your price point.
The only Mr.Speakers I have heard extensively was the AFC. It was very nice sounding and comfortable. That being said it lacked slam as well as texture,so a very large change from the ZMF house sound.
Reactions: gimmeheadroom
post-15713114
Post #4 of 15
Crazeenick
Morecambe
Morecambe
I'm using leather pads with the Eikons.
I tried swapping pads on a ZMF Atticus from leather to suede and it made them less bright. So I assume sticking with leather pads is probably best of the Eikons....
post-15713180
Post #6 of 15
Monsterzero
post-15713282
Post #8 of 15
Monsterzero
I'm not sure I understand that chart! Which earpads would I move to in order to make the Eikons sound brighter?
Personally I would ask @zach915m
ZMF goes out of their way to make sure their customers are satisfied.
The only dynamic HP ZMF makes that I have no experience with is the Eikon,so I cannot advise.
post-15713412
Post #9 of 15
You'd want to try the universe pads for a brighter sound, the Eikon is already fairly neutral and not a dark headphone already, it's pretty neutral with a bass rise. Also - using suede will make them brighter. Lots more info on our website here too:
https://www.zmfheadphones.com/zmfpads
ZMFheadphones ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship. Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
https://www.facebook.com/ZMFheadphones https://twitter.com/ZMFheadphones https://www.instagram.com/zmfheadphones/?hl=en http://www.zmfheadphones.com/zmf-originals/ contactzmf@gmail.com
Reactions: Monsterzero
post-15713487
Post #10 of 15
Crazeenick
Morecambe
Morecambe
Zach - so would the Universe pads in ZMF Suede (non perforated) be the best choice for making the Eikons sound brighter? And will this leave the bass unchanged? (I like the sub-bass and bass on the Eikons as they are with the leather Eikon pads!).
post-15713688
Post #11 of 15
I'm that case either eikon hybrid or Auteur lambskin or hybrid would be good. As universe will decrease the bass.
post-15721257
Post #12 of 15
Crazeenick
Morecambe
Morecambe
So - to make Eikons sound brighter without losing bass - maybe I should try Eikon Hybrid pad or Auteur Hybrid pad? Which one would sound brighter?
Would it be worth also changing the cable on the Eikons? Any recommendations (below £400) for increasing brightness (without decreasing bass)?
Would silver be better, or would copper ones be best?
Any advice folks?
post-15721261
Post #13 of 15
Monsterzero
For increased energy in the treble area you want silver. You shouldnt lose any bass response,but it might sound faster than what you're used to.
post-15721286
Post #14 of 15
Crazeenick
Morecambe
Morecambe
Can anyone recommend a decent silver cable that doesn't cost an arm and a leg? (eg under £400)?
post-15721455
Post #15 of 15
Monsterzero
Ummm...Ive owned two silver/hybrid cables. One was made by a guy who was quite well know in this community,but apparently he is no longer in the cable making business.
The other was made by ZMF.
