MannerPylon
- Oct 17, 2010
Got my Flows in hand! Well... in box. Now I get to watch the clock and wait until I can leave to run home to listen
A few things about unboxing and first impressions.
*the box and packing have got a nice upgrade and look quite slick and professional now, befitting a totl flagship product
*the DUM cable is no longer KINKY!! YES!!! This is now a very usable and well behaved cable (thanks for this Dan).
*even with no "burn in" these impress right out of the box. I guess it's been about a month since I had flow in house. Man did I miss them.
CLASH OF THE TITANS...
All have pure silver cables..
Time to listen...
I am scared..
Time to listen...
I am scared..
The HE1000 was high on my list before I purchased the Flow (and later the Utopia). Interested in your thoughts!
Do you have an hd800 moded to use as frame of reference?
Yeah those initial impressions were straight out of the box with ZERO burn in..
We can expect micro improvements with burn in, but essentially the main signature and presentation will be the same..
Usually from planars, the bass improves as also the detailing,
But it is already highly detailed, not just average, but well above almost at the HD800 level,
so it hard to imagine how much better it can get..
Preliminary observations..
Resolution detail and realism is right up there "neck and neck" with the two other TOTL cans (which are cheating because they are modded) and not a step down...
Signature is very liquid.
Bass is very present.
Focus is very clear.
Realism is high.
These will even make your dull recordings sound more alive
Realistic trebles
Realistic mids.
A bit of lower bass emphasis which is impressive in its articulation.
Notice I haven't mentioned what I am very picky about ,
Which is soundstage.
Reason being that I am used to the to other TOTL cans (HEK & HD800) which have the largest soundstage or any headphones.
So I must put things in perspective.
The depth of field is excellent as you can hear greater depth than an LCD-X.
The image height is actually quite excellent as it has a nice LArGE soundfied.
Soundstage width is good too.
I was anticipating more distance, and greater staging comparable to HD800 & HEK,
but these Flow have you sit in the audience a few rows closer than those two..
Probably more like the LCD-X in terms of soundstage proximity...
The strengths of the "Flow",
is the very "alive" soundfied it produces.
Everything sounds more immediate and with more energy or presence while simultaneously having an utter smooth liquidity in signature...
