It's a transformation box. Makes a terrible amp sound nice. And a nice amp sound terrible. Transformers
transform, right?
Yes, it was my (cheapskate) transformational solution, using a multi-tap 70V traffo.
Me too.
He should. But will he?
Sure does.
Yes it is. Not different, just a pair of the same type - OSD Audio 70V line matching with 1KΩ, 500Ω, 375Ω and 250Ω taps for input and 4/8Ω output taps. See the mini-wire snake at
this post.
No Triple Dual Mono Mojo.
But that sure is a tempting option. Wonder about a higher output impedance (80-120Ω) for high impedance phones... but appears their AN-130 is the top of the range.
However, since moving up the OTL sound train from coach to snob level, have found the TS 5998 or WE 421A can drive my Aryas and other low impedance phones very well without requiring electromagnetic transformative intermediation. In fact, the EL86 is pretty good as well. Although, I listen at reasonable levels and mainly small acoustic ensembles or solo instruments, so rarely need big loud boom boom power.
Still...to my ears. 'normal' AC regulator tubes like 6AS7/6080 do perform better with planars connected to a traffo-house.
