jagwap
Expectation bias is what you're hearing there.
As we've discussed before: Expectation bias can work both ways. You won't hear a difference if you don't want to.
but from what i see, saying "loseless" is just a marketing.
[1] Actually im a fan of DSD format, which for me sounds really analog and natural (like it better than hi-res, for me is just a feeling of naturalness and fullness). ...
[2] Thats for sure, but i bet that when u listen to the DSD, u can feel something more, like bit more of richness. Or its just my brain.
I do have an expectation bias of not hearing a difference. That expectation bias was caused by not hearing a difference in double blind testing!
G
But not hearing a difference in double blind listening tests can be caused by an expectation bias that no difference will be heard.
That's what I'm saying. I've failed to hear a difference in a double test, which could be due to an expectation of not hearing a difference, an expectation caused by some previous double blind test which demonstrated no difference.
In practice of course, with a double blind test we are actively trying to hear a difference, if we weren't trying to hear a difference what would be the point of running a differential test in the first place?
G
because we're testing the null hypothesis: "there is no audible difference". the all test is about finding people who can disprove it by showing they perceive a difference. and to talk like a pro in statistical technical jargon, F everybody who can't ^_^. if I pay 200 guys to pick at random, and you get your one guy to pass, the conclusion will still be that there was an audible difference.But that is not my point, and I think I made it clear. I think double blind tests are susceptible to bias, which is skewed in one direction: towards allowing subjects to only get caught out when they think there is a difference and there isn't, not the other way around.
The purpose of an ABX listening test is NOT to show that 2 separate files sound identical. It is used to show that a difference can be identified. If someone claims to be able to hear a difference, those are the people that should be attempting an ABX to verify if their claims are valid or not by removing the most obvious of known biases and to better isolate the listener's hearing.But that is not my point, and I think I made it clear. I think double blind tests are susceptible to bias, which is skewed in one direction: towards allowing subjects to only get caught out when they think there is a difference and there isn't, not the other way around.
My assumptions about audio come from measurements and what I have read about human perception and hearing. I don't base any claims solely on the results of failed ABX tests. ABX tests are used in situations where the question being asked might be, "Can anyone hear a difference?" Nobody would seriously consider using an ABX test to answer the quesion, "Are these the same?" That is were analysis and measurements are used.
The whole point of a comparison test is trying your best to consistently discern a difference. If I do a careful test and something appears to be audibly transparent, then that is good enough to me. There may be a slight difference if I crank the volume or strain to hear some very specific sort of sound, but I really don't care. That's a molehill compared to the mountain of bias in the completely subjective impressions we see in audio forums.
If I can't hear it in carefully testing, it's close enough for government work for me.
That still doesn't prove the files are the same, only that the person taking the ABX was unable to identify a difference. That doesn't help anyone else except the person taking the ABX.Then you should be replying to the people who said they did double blind tests to prove to themselves there is no difference, not me.
