Originally Posted by Gringo /img/forum/go_quote.gif
points 1&2 Any CD or audio file either streamed or downloaded has to be sampled regardless off the original master being analogue or digital which you obviously already understand.
therefore new improved sampling using latest technology of analogue will inevitably produce better results. As you will know DACs have come on a long way.
For decades now masters have been generated digitally, which again you already know, therefore being able to deal with the unwanted additions the original digital process applied to the recording is beneficial. This is not simply increasing or decreasing specific frequency range i.e equilisation. In fact if we could remove much of the original equalisation the studios have in fact applied to make music stand out in the loudness wars over recent years that would be brilliant, (I am not claiming MQA does that)
I repeat again. No one, repeat no one is claiming that what was not originally captured can be restored. Meridian are not claiming MQA is completely lossless, only that "the human hearing system is sensitive to about 10 microseconds in time resolution and here’s the kicker: much/most of this resolution is destroyed in anything encoded digitally below a 192kHz sampling rate",. With MQA this hi-res data is stored completely below the noise floor thus reducing file size significantly. If you don't have a decoder the file plays as a regular PCM file so it won't cost you a bean other than the purchase of the file. MQA requires to be decoded to get the full benefits and that is where the additional cost kicks in, (only if you want it). Streaming/downloading services don't have to store different versions of millions of albums plus all the backups.
this link might be of help, it is nearly 9 mins long and explains in general terms what its all about. It does not go into great technical detail, I guess Meridian are not going to let anyone near that for obvious reasons- https://m.youtube.com/watch?v=VvIGzGWSK48
Ask your self this after watching the video. Why would someone go to all the bother of developing a technology that you can use for free unless they were certain that you will want to invest in the technology to gain the full benefits.
I am not going to pursue the thread any further, I have done my limited best to dispel some misconceptions and I repeat for the last time. You don't have to believe anybody, listen for yourself and then dismiss it as rubbish if you think it is, if you don't want to listen then that's OK if your happy with that. Because we don't understand something does not make it wrong any more than accepting something just because someone says so is equally wrong but I guess that's a lesson from history all cultures have chosen or mistakenly ignored.
Happy listening
