FastAndClean
Previously known as presata
i love them, just returned back to them today after a couple of days honeymoon with ****, they are just spot on for me5th. I like the Kanas Pro.
Spot on!I just caught up on this thread. I just wanted to make some comments regarding the video youtube review posted...
1st. His measurements match mine exactly that I posted in my review and on this forum. I have the EARS unit and I used Dayton IMM-6 and they pretty much look the same if compensated.
2nd. His sound demo sounds wrong to me. Midway through the review, he started to mod it, which is interesting considering I posted all the mod options and how tuning changes slightly a couple weeks ago -- including jamming foam in the tip
3rd. The MiniDSP EARS will sound unnaturally weird if you listen to it using a set of IEMs without the proper compensation curve applied. This is because it's depth is like 6mm deep and it will get some resonance from the silicone EARS material used for the ear canal and ear itself. I dont know if and how he compensates for this -- MiniDSP provides a compensation for REW data analysis, but you'd have to extrapolate that data to an EQ properly to possibly make it sound realistic for a music trial. I asked him in a youtube comment and he just blew me off saying he already explained it -- which is never explained in any of his videos as far as I am aware -- granted I have not seen every review.
4th. Measurement rigs, even the most expensive industry ones, do not accurately measure pass 10KHz. This is partially why the Harman Target for IEMs stops at 10KHz. Human hearing after 10KHz can vary a lot too.
6th... he provides a ton of comments on sound demos and then at the very end he says he doesnt like the rig because it doesnt sound right...
https://www.head-fi.org/threads/moo...pressions-thread.894139/page-82#post-14801524No not yet. Havent had any time. Quit my job this week and had a lot of after work celebrations.
I may have time this week to do some more tests before I start my new job in a week and half.
Can you remind me what you want tested?
I`m neither and experience things as I do. I experienced "burn-in" with KPE and I don`t feel myself religious nowI swear.
Burn in believer=Religious people
Non believer=Atheist
@antdroid ,have You managed to try out that filter mod I suggested? Or have You settled with some new mod You haven`t told us?
Btw, meanwhile I tested some different filter papers and even to slight changes in thickness/porousness KPE is very sensitive/reactive.
luckily I`m settled atm with one certain nylon+paper combination and enjoying heck out of these ;P
1st. His measurements match mine exactly what I posted in my review and on this forum. I have the EARS unit and I used Dayton IMM-6 and they pretty much look the same if compensated.
He is simply spoiled by etymotic smooth treble. BTW he explained it on some of his review, he is compensated it by ear (because his rig limitation) and modified his compensation EQ a few times because he never satisfied with it.
how dare you, how dare you kind misterI removed Moondrop Crescent's biggest flaw, and attached a non-flaw
So far I've found the sound demos very helpful. Reviewers usually also record IEMs that I own so I can hear how the sound is tilted by their recording and my listening equipment. So far bass intensity, texture, mids, high details and pretty much the entire sound signature I could deduce from a sound demo. When I got the IEMs what what I was expecting.
