Moondrop in-ear monitors Impressions Thread
Sep 11, 2021 at 4:00 PM Post #9,991 of 10,355
biostik
Netherlands
Variation’s bass is sub-bass focused, so if any mid-bass oriented instruments are on stake, it needs ear tip rolling, or recabling. I found myself comfortable with PW Audio’s Copper 28 V2 for the midbass coming out of Variations.
Yes, tip rolling is the first thing I do usually. I think the cable will be more fine tuning the sound. How does the Variations actually react on EQ ? I can always give a bump into the upper bass
Sep 11, 2021 at 8:28 PM Post #9,992 of 10,355
bcaulf17
Do note CP155 fits to B2/Dusk/Variations, but it alters the sonic resonance due to nozzle length and bore size.
For less alteration: wider bore /longer nozzle CP800, wider bore /shorter nozzle CP360 would work.
The new CP100 plus also does good job for Dusk, it’s a vocal region booster.
Yeah, I’d rather have a set that doesn’t alter sound as much but improves comfort.
Sep 11, 2021 at 10:36 PM Post #9,993 of 10,355
seanwee
Sep 12, 2021 at 11:29 AM Post #9,994 of 10,355
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
Austria
Thank you for the tips. For me, Variations' bass is too much. MEST MKII could be my perfect fit then. RS10 will be my ultimate goal. I am not ready for it yet.
I also found the variations having too much bass with some tracks and too thin lower mids. Went back to tip rolling and found that the Spiral Dot ++ even out the frequency response.
I am enjoying them a lot now, exceptionally clean sound, very good layering, detail and imaging. Really good value.
Sep 12, 2021 at 12:12 PM Post #9,995 of 10,355
Ufanco
Been really happy with the epro and jlab wireless tips. Might try the spiral dot ++ if can find a decent price on them. Amazon has them for $30 for 2 pairs. Are they really that much better than other Tips? If anyone knows a cheaper price or has a extra large size they can part with please let me know.
Sep 13, 2021 at 1:23 PM Post #9,999 of 10,355
Strifeff7
Indonesia
I use the Fiio BTR3k when commuting, is this enough to drive the Variations properly (balanced that is)?
I only have the BTR5, at volume 30,
the BTR3K should be fine,
Sep 13, 2021 at 5:48 PM Post #10,000 of 10,355
nihil23
Moscow
Just checked moondrop link app and find this. @MOONDROP, how soon is new tws?
Sep 14, 2021 at 6:09 AM Post #10,002 of 10,355
Chengdu,China
@MOONDROP I too want to know more about the special line k upgrade cable preorder bonus. Details are very scarce for something with limited (preorder) availability.
It's just basically a SPC cable with plug of your choice.
Not much to say...
Moondrop Stay updated on Moondrop at their sponsor profile on Head-Fi.
https://www.moondroplab.com
Sep 14, 2021 at 6:10 AM Post #10,003 of 10,355
Chengdu,China
Sep 14, 2021 at 10:19 AM Post #10,005 of 10,355
Lamim Rashid
Not much to say...
What makes it an upgrade cable then? Lmao. You can get an spc cable for as cheap as 5-10 bucks on Ali these days bute they're all crap and never last long. I don't care about the wire snake oil stuff, how one might sound better than the other. I just want something good quality that will last long. So let me rephrase my question, what makes this preorder bonus cable better than the stock cable?
