I recommend those who are considering the Variations and planning to use aftermarket cables with it to wait. I swapped XINHS cables about 3 times and the 2-pin sockets one is broken and the other has some cracks in it which will go into pieces very soon. Unless you are only planning to use the stock cable or cables from Moondrop, you are very likely going to break the sockets and XINHS they make 50% of the market's cable, all I can say is good luck with your copy.
I am sure I can send it back for repair, however, if they are replacing with the same socket holders I will definitely break them again. I have like 40 pairs of IEMs and this is my first time breaking the sockets without even really using it. I mean this is MY VERY FIRST TIME breaking the sockets at all.
