Moondrop in-ear monitors Impressions Thread
- Thread starter FastAndClean
Just ordered the SSP for no other reason than I had a £10 voucher on eBay so I thought why not.
Codename john
The illumination looks like single driver endgame territory. If I win the lottery , they will be the first thing on my list
imackler
- Nov 17, 2008
- Messages
- 5,776
- Reaction score
- 380
The filter on one of my buds is a little off-center. The black ring around the filter goes right across one of the small tubes. Will that affect the sound?
bagofolives
A little, but honestly after switching ear tips they were long gone for me. They were too much of a hassle to keep on and I was more worried of them ending up in my ear than the ring blocking them a little.
post can be removed..
Where is this?
MrDelicious
Looks like the coupon is gone, boo.
slimjourney
Having my Moondrop Blessing 2s on the way now, just want to ask a couple questions:
- Do they scale well with balanced output and/or amps for example?
- Will I be missing out on its capabilities/potential if I just run them straight off my SonyA105 Walkman, phone or laptop?
As far as I can hear, not so much, except well louder. I use zx507, sound good on SE or Balanced.Having my Moondrop Blessing 2s on the way now, just want to ask a couple questions:
I think no, Blessing 2 is good because it sounds so good in general IMO.
I suggest running the B2 off balanced simply because they are quite power-hungry, I found.Having my Moondrop Blessing 2s on the way now, just want to ask a couple questions:
I'm curious what you're running these from that the single ended output is not enough for b2. I guess I could understand somebody saying use an amp for them but to say they should be running balanced seems a bit overkill.I suggest running the B2 off balanced simply because they are quite power-hungry, I found.
now obviously if somebody has an amp that has both balanced and single-ended outputs in general the balanced output sounds better on most of those amps so you would use the balance output just for that purpose but I would never recommend that somebody specifically looks for a balanced output to run B2
MOONDROP
Member of the Trade: Moondrop
If the ring was covering the tube, there will be a quite minor effect.The filter on one of my buds is a little off-center. The black ring around the filter goes right across one of the small tubes. Will that affect the sound?
our IEMs comes with some replacement filters, sorry for the inconvenience.
edit:replacement filter comes with KXXS/Starfield/illumination only/
For blessing2/s8/solis series, just get the original filter off and use tweezer and apply another.
For KXXS/Starfield/illumination/SSR series, check out this video:
imackler
- Nov 17, 2008
- Messages
- 5,776
- Reaction score
- 380
Where are the filters in the Blessing 2 packaging? I purchased my pair new from Headphones.com and I can't find them anywhere inside the packaging. Thanks for your help! Maybe I'm missing them but I've looked pretty closely...If the ring was covering the tube, there will be a quite minor effect.
I removed my Blessing 2 filter since it moves a lot when I changed eartip, and I couldn't find the replacement in the box too...If the ring was covering the tube, there will be a quite minor effect.
