Moondrop in-ear monitors Impressions Thread
post-15695571
Post #5,776 of 6,145
Slater
Cincinnati, Ohio USA
As previously mentioned, the housing was from these "imperfect" KXXS shells which didn't have perfect mirror finish. While the diaphragm for KXXS are DLC coated and for starfield is super aligned carbon nanotube coated. The cable is also different.
Ah, ok. Thanks, very helpful explanation.
post-15695605
Post #5,777 of 6,145
IEMusic
Florida
Florida
post-15696844
Post #5,779 of 6,145
FastAndClean
Previously known as presata
mars
mars
Website
www.youtube.com
wide bore = best possible sound with Blessing 2, get yourself wide bore tips, Sedna probably ideal, JVC spiral dots also, i personally use Fostex TE-02 tips
the stock tips are comfortable but the opening at the end is not wide enough for optimal openness in the sound department
post-15696912
Post #5,780 of 6,145
Octavius
Moldova
Moldova
And also i can recommend(again) symbio eartips, they also have wide bore, but I can also recommend them to those who are looking for a stronger bass impact, due to hybrid construction( foam+sylicone) + wide bore, the bass is more defined and it has a better punch, but without any detalisation loss, the difference is very obvious comparing stock tips. With symbio eartips I can listen some metal, with stock eartips doom/death metal sounds too softly.
post-15697068
Post #5,781 of 6,145
M3NTAL
Has anyone see any news regarding the Moondrop full-size over-ear headphone? I've seen some photos from the show and couple of the driver assembly, but nothing about them.
post-15697187
Post #5,783 of 6,145
M3NTAL
Your EJ07 took a wrong turn somewhere I think :beerchug:
post-15697192
Post #5,784 of 6,145
phthora
Albuquerque, New Mexico
post-15697208
Post #5,785 of 6,145
IEMusic
Florida
Florida
post-15697849
Post #5,786 of 6,145
Banbeucmas
Hanoi, Vietnam
Hanoi, Vietnam
Website
banbeu.com
Starfield vs. IBasso IT00?
I had a listen with Ibasso IT00. Although not much
But I got to say the IT00 sounds more exciting than the Starfield.
post-15697906
Post #5,787 of 6,145
Electrolite
Brazil
Brazil
I won a Starfield from a Twitter lottery. Not sure if I can add anything, it's been extensively reviewed but I like it. It has a good bass response with decent impact, mids are present and fluid, treble lacks some attack for me but are detailed. It's a balanced headphone with a good warm-ish timbre.
T2 is close to it but but loses in tonality, sometimes the T2 is sibilant and also lacks some bass for me. I also think the Starfield got a bigger spatial effect/imaging, not sure which, but it feels more spacious and open.
I'm also using oratory1990's EQ setting, I think it improves the IEM it lowers the 1k and increases treble a bit.
Link to EQ settings: https://www.dropbox.com/s/73k54n642lerrjf/Moondrop Starfield (oratory1990).pdf?dl=0
I plan to buy new tips, I think I'll go with Spinfits CP145. Anyone else has other suggestions
Reactions: GodEmperor
post-15698484
Post #5,788 of 6,145
Qualcheduno
Italy
Italy
Age
25
So, I've been listening further to my Starfield and comparing it to my HD650, and I tend to agree with the guy here (I don't remember who) who said that the former is a baby version of the latter with better bass extension, with some caveats on the tonality (I will not talk about technicalities since we are talking about different price points and form factors): the starfield is even smoother, but sometimes instruments like distorted guitars lack a bit of crunch and bite, while on the other hand the senns are a bit more upfront and aggressive but tend to show some harshness from time to time, esp in bad recordings.
post-15698793
Post #5,789 of 6,145
IEMusic
Florida
Florida
If anyone finds the Starfield a bit too smooth, perhaps a bit boring, and lacking “bite”, I’d consider trying ePro Horn-Shaped tips. I really like them on the Legacy 3 and the T4. They make the sound a lot more lively, akin to a horn-loaded speaker, IMO. Alas, I don’t have the Starfield to try them on.
post-15698832
Post #5,790 of 6,145
Skullar
Uk
Uk
Ha, another E-pro Horn Shapes lover. They are absolute best sounding tips ever. But seem to be overlooked by others.
Fit might not be for everyone, as they are quite deep insertion. But what they do to treble and staging its just pure magic.
I suppose they are not best pick with bright iems.
Reactions: requal and IEMusic
Users Who Are Viewing This Thread (Users: 5, Guests: 9)
