Moondrop in-ear monitors Impressions Thread
Jun 22, 2019 at 12:46 PM Post #3,256 of 11,972
i think the regular Kanas is a side grade, they use the same driver and body just with different damping to lower the bass level on the pro version
@chickenmoon have them both, he can confirm
They are very similar, more bass on the regular and that's by far the biggest (perhaps the only) difference in sound. The upper mids plateau might also be just a tad more elevated on the regular.
Jun 22, 2019 at 1:25 PM Post #3,257 of 11,972
I wish I had the kanas to compare with the kxxs. I can say the sub bass on the kxxs is very good. It sounds like a very high end stereo system, Very clean, clear and has depth. I'm not sure how to explain it but it sounds deep and far away somehow like there is space around it.. My NHB-108 sounds like that but much more so.
Jun 22, 2019 at 1:30 PM Post #3,258 of 11,972
i know what you mean about the bass, very clean, not the fastest but it sound like very good musical subwoofer, is rumbly and smooth, airy kind of bass that is spread out, hard to explain but i want it again, that is the reason why i bought the Kanas
Jun 22, 2019 at 2:05 PM Post #3,259 of 11,972
I love listening to my KPEs for hours everyday but I would kill to have your 2 channel setup.
Your Cornwalls must sound amazing powered through your NHB-108 clone , they are $2999.00 each here in Canada.
Jun 22, 2019 at 2:13 PM Post #3,260 of 11,972
I got it on aliexpress for around $680 shipped a few years ago. I just found the cheapest one on there. The only thing annoying is the extreme break in time. It sounded so bad when I first turned it on. I thought I got ripped off but after 500hrs it came alive. Well it came alive before that but it didn't stop changing till 500 hrs.
Jun 22, 2019 at 2:30 PM Post #3,261 of 11,972
What did you pick your Cornwalls up for if you don't mind me asking?
Jun 22, 2019 at 2:37 PM Post #3,262 of 11,972
Actually the NHB isn't a real good match for the cornwalls. At lower volume it's great but I can't take the mids with it loud. It rocks with movies. It sounds holographic. Cornwalls need a dark amp to be played loud like tubes or older harman kardon amps. I have an hk930 from 1973 I think that goes great with them but it doesn't have the magic of the NHB.
Jun 22, 2019 at 3:17 PM Post #3,266 of 11,972
KXXS frequency response
(RAW calibrated measurements from miniDSP Ears)
(300Hz 94dB normalized, R_IDF compensated, 1 pass, 1/48 smoothed)
Edit: I've decided to use the included IDF compensation and updated all the graphs
Edit2: I am still not happy with the results. I am re-doing all my measurements and will be posting them soon.
Baseline: Etymotic ER4SR (3-Flange) vs Moondrop KXXS (CP145 Spinfit) vs Moondrop KXXS (CP100Z Spinfit)
Against Kanas Pro: Moondrop Kanas Pro (CP145 Spinfit) vs Moondrop KXXS (CP145 Spinfit) vs Moondrop KXXS (CP100Z Spinfit)
Hi-Fi: Moondrop KXXS (CP100Z Spinfit) vs AK T8iE (default) vs Andromeda S (Final E) vs Dita Answer (Spiral Dot)
Ocharaku: Moondrop KXXS (CP100Z Spinfit) vs Ocharaku Donguri-Kaede (default Spinfit) vs Ocharaku Donguri-Keyaki (Comply)
Jun 22, 2019 at 4:37 PM Post #3,267 of 11,972
(300Hz 94dB normalized, R only, 1 pass, 1/48 smoothed)
KXXS (Spinfit) vs Kanas Pro (Spinfit) vs Etymotic ERSR (3-Flange)
KXXS (Spinfit) vs Dita Answer (Spiral Dot) vs AK T8iE (default) vs Andromeda S (Final E)
KXXS (Spinfit) vs Donguri-Kaede (Spiral Dot) vs Donguri-Keyaki (Comply)
In your opinion what is the difference between the Kansas and the kxxs?
Jun 22, 2019 at 5:12 PM Post #3,268 of 11,972
Anyone remember what price MassDrop was asking for the A8?
thanks
Jun 22, 2019 at 5:15 PM Post #3,269 of 11,972
Jun 23, 2019 at 12:12 AM Post #3,270 of 11,972
