Moondrop in-ear monitors Impressions Thread
post-15017640
Post #3,211 of 5,500
hakuzen
i had same issue with crescent (one side started to sound very low), after first 4 hours session. inspected the mesh, vent holes.. nothing found.
opened both shells, and found that the PCB on the "damaged" driver was covering the small center hole of the driver, while the hole in the other driver was visible.
still don't know if that was the cause, because broke the wires of the driver when opening it, and i haven't soldered them back yet (i plan to do the mmcx mod on them)
Reactions: SpeedyClaxton4
post-15017685
Post #3,212 of 5,500
SpeedyClaxton4
It's unlikely the cable, I've swapped sides and the right bud remains fine regardless of which end it's on, while the left bud remains muffled regardless of which end it's on. I don't think I have any other two pin cables unfortunately, all my other current IEMs are MMCX.
How difficult is it to remove and reinsert the mesh filter?
EDIT: I think I fixed it. I was very delicate taking the mesh out. I then listened to the IEM without the filter and the volume on the left side was fine, obviously this affected the FR, but confirmed the driver itself was likely fine. After attempting to clean and reinsert the filter a few times I think I managed to fix it. All seems fine now...Strange, the mesh didn't have any visible signs of clogging, but obviously it was enough.
post-15017967
Post #3,213 of 5,500
morndewey
Well, I thought I found a good fitting set of tips for KPE but it proved ephemeral. Out of desperation I finally took someone’s tip fit mod advice and sliced off the inner barrel from another set of tips. I then cut these little rubber sleeves in half and attached them to nozzles like a spacer or washer would be. This really did the trick. I am astonished by how good KPE sounds now, by what I’ve been missing. Every tip I tried prior to this always got pushed too far down the nozzles and interfered terribly with fit. I am just like Wow at the sound. There is genuine rich balance. Using foams, small size, less spongy than Dekoni or NewBee. Slightly firmer than these. The foam cuts down on some of the sharpness of the sound too. With spin fits they sound too sharp for me. Spiral dots too. Whoever it was that suggested this hack, thank you!
post-15017989
Post #3,214 of 5,500
416805
if u got warranty IMO i rather just claim the warranty and getting it repaired by them instead of DIY-ing yourself
but
if its over, nothing u can really do tbh. trial and error ot goes
post-15018501
Post #3,215 of 5,500
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
Glad You finally got the "right" sound out of KPE :wink:
post-15018511
Post #3,216 of 5,500
416805
tried the TFZ No 3 today
i don't think they are the type of upgrade kanas user want.
IMO not a significant upgrade altho this is from 30 minutes impression (which i think is not enough to judge so take it with a grain of salt)
Reactions: LaughMoreDaily
post-15018555
Post #3,217 of 5,500
MariusAB
Lithuania
Lithuania
How is the bass compared to kanas pro? As my tfz is coming to me so we will see soon what it gives compare to kanas. Actually i dont see till now any real upgrade from kanas pro till 400- 500 eur only sidegrades but tfz no 3 price was so good and decided to give tfz a chance. But even if it is sidegrade for this price is really good deal.
post-15018566
Post #3,218 of 5,500
Evoke
Having own a KPE I love to hear how does the Sony Ex1000 and the Ex800st compares. I might have the chance to audition it if I go Japan next month
post-15018587
Post #3,219 of 5,500
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
Austria
Austria
For the EX800 try the search function. There has been so much talk about it in this thread that the moderators had to jump in to get it back on track...
It‘s all there!
post-15018618
Post #3,220 of 5,500
416805
the bass probably got more quantity around midbass area.
it is slightly more emphasized than the kanas pro.
the nice part about it is that they tame the uppermid part so female voice doesn't get as shouty.
but stage wise kanas is bigger, details i think they are about the same. no 3 feels abit more detailed because everything is closer while kanas is slightly further.
it just a warmer kanas pro with uppermid/treble reduction.
upgrade from here:
EX800, its still the king of budget if u got no problem with the signature. IMO league above the kanas pro interm of technicalities. but not everyone gonna like the sound signature it can be abit ouchie afterall.
Blessing is an upgrade interm of technicalities. u get better resolution too. but the bass is not as good as kanas pro. u might not like it
honestly under 500 euro u can get Fearless S8 Pro/moondrop A8 which is a big step up from kanas Pro.
If u fancy yourself to mod
try to do the FD01 mods, i never tried it myself but people i trust tried it and they swear its one of the best DD u can get. problem is without mod it doesn't sound good at all
i totally recced the A8 if u like moondrop sig. IMO the best sounding moondrop so far.
post-15018764
Post #3,221 of 5,500
ckvp
I have not stopped listening to my KPE since receiving them yesterday. :ksc75smile:
Edit: That is an accurate portrayal of me since.
Reactions: scotvl
post-15018782
Post #3,222 of 5,500
CoiL
Estonia
Estonia
I`m fine with mid-bass of KPE - I do not like any bit of "raised" mid-bass and this is why KPE is so special to me with its "dead-flat" mid-bass.
...female voice doesn't get as shouty.
No problem with that either with KPE. Not shouty female vocals to me.
And this is also what I really like. KPE doesn`t have monstrous soundstage and overly artificial like ZS5v1 for example but still sounds quite "holographic/3D".
Imaging is also spot-on imho (I don`t like closed-in/in-your-face/inside headstage imaging and presentation - I like it open/airy and wide, kinda like open-back headphones (bad analogy I know).
I know if I didn`t have KPE, I would probably choose No.3 because of price and SQ but atm I`m wondering if TinHifi/Audio P1 would be upgrade in every department?
I really wish to get my hands&ears on properly done "cheap" chi-fi planar :p
Reactions: 416805 and scotvl
post-15018812
Post #3,223 of 5,500
416805
almost similar to me, but i prefer no mid bass if it bleeds but if it doesn't it gives a nice body to the music and mid bass and lower mid sounds fuller so there is that too.
total preverence tho.
yup this one is entirely subjective. they do sound sweet in most tracks. some track i need to lower the volume down.
actually pretty spot on, a vent airy and stage feels much better than treble stage try to play around with the treble u will see the "airiness" from the treble. zs5 is just excessive i hate it.
kanas do have above average soundstage but they are natural from the vents.
ex800/1k is the best in this regard because of their vents.
price is really amazing for this set, $100 i can easily rec them to most of my friends.
As for P1, the person that i trust doesn't seem to think that highly of em and i don't think im gonna try em. IMO with kanas u should get an upgrade instead of a sidegrade. something like A8 or the likes of that.
post-15018859
Post #3,224 of 5,500
ckvp
3D printed this to protect my new toy:
Didn't trust the little velvet pouch in my bag.
Edit: If anyone wants one, or something similar, I would print it and ship it at cost for you, just PM me!
post-15018886
Post #3,225 of 5,500
416805
nice, but i would buy 2 micro fibre. one to cover the inside of the case so when the iem didn't rub aganst the plastic creating scratches.
the 2nd micro fibre is to wrab and make sure the iem didn't rub against each other.
Users Who Are Viewing This Thread (Users: 22, Guests: 12)
