Our goal has been to create a product that combines aesthetic design, practical functionality, and excellent sound quality at a cost-effective price attractive to consumers.
Today, let's unveil the result, Edge, a set of noise-canceling headphone with clear bass, smooth treble, rich details and accurate sound reproduction. It's priced at US$79.99! Learn more about this wireless ANC headphone!
In order to provide a solid hardware foundation for its acoustic and noise-canceling performance, Edge has adopted a large 40mm dynamic driver unusual in headphones of this size.
With its large N52 magnetic circuit, lightweight CCAW voice coil and ample vibration stroke, the driver provides superior low-distortion performance and excellent dynamic range.
Edge supports LDAC, a high-resolution wireless audio protocol widely used in Android, which can deliver high-resolution wireless transmission with larger dynamic range and wider bandwidth.
Edge adopts hybrid ANC combined with FF (feed-forward noise canceling) and FB (feed-backward noise canceling). Each side has two high-sensitivity microphones, resulting in a four-microphone noise monitoring and feed-backward system that re-calibrates the ultra-wideband high-threshold deep noise cancelation, producing superior, comfortable ANC in a variety of wearing conditions.
Edge takes full advantage of the size of the headphones to place two microphones at sufficient distance to provide beamforming ENC. During calls, Edge will pick up the user’s voice through beamforming positioning and block noise from other directions, delivering clear calls even in a noisy environment.
Users can easily switch to transparent transmission mode by pressing the ANC button, thus enabling clear conversation without removing the headphones.
Edge makes full use of the extra space available to incorporate a large-size onboard antenna with ample clearance from other components, resulting in excellent stable signal transmission.
Under normal conditions, a smartphone with good connection performance can achieve a transmission distance of more than 50 meters.
Multiple experiments have demonstrated that even in complex electromagnetic environments such as airports, Edge can maintain a continuous connection at distances up to 50 meters.
Thanks to its built-in large-capacity battery, Edge supports up to 48 hours of continuous music playback, high-speed charging, and four hours of music after only 5 mins of charging.
Edge comes with five built-in tunings. In addition to the default tuning, it also simulates the tuning styles of some distinctive classic headphones. Users can select their preferred tuning through the MOONDROP APP.
Any comments are welcome.
Stay updated on Moondrop at their sponsor profile on Head-Fi.
