mill999red
- May 1, 2006
Moon Audio Black Dragon Premium Cable for Sennheiser HD800/HD800S Headphones V2 5 feet
Black Dragon V2 Premium HD800 headphone cable is the ULTIMATE choice for your Sennheiser HD800. It includes premium Rhodium Furutech Connectors that both look and sound amazing!
It is extremely smooth sounding with great low end and wonderful voicing. It is not a laid-back lush or dark sounding cable. It smooths out the top end making it a little less analytical and a little more natural sounding. It also adds bottom end weight to the lower frequencies and provides a fuller sound and wider soundstage.
Amp termination = 1/4“ Furutech Carbon Fiber/Rhodium CF-763 plug
Headphone termination = Furutech carbon fiber/Rhodium HD800/HD800S connectors
Length = 5 feet
Excellent cable….I moved my amp and now need a longer one.
New $415
The difference between the Standard Black Dragon and the Premium Black Dragon are the connectors used on each end and a harder to work with higher silver yield solder. The wire is identical. When you are trying to squeeze out every last percentage point of performance, the Premium version makes sense. The Furutech Top Line connectors are quite simply the best made. And every point of signal saturation will make a difference. Is there a night and day difference between the sound quality of the standard and premium? No. Is the Premium the best of the best? Yes. These cables are meant for the cream of the crop headphones where every little thing makes a difference in terms of bring you closer to audio nirvana.
Most stock headphone cables are made of poor ultra-thin conductors that work as a bottle neck for the sound but the Black Dragon V2 cable uses 4 x 21.5AWG Teflon insulated stranded conductors using pure single crystallized UP-OCC pure copper with 7N purity 99.99998%. Yes, you will be able to hear and see the difference in our hand-crafted cables!
Each conductor is made up of a special varying size stranding geometry. The copper stranding is mixed with Kevlar stranding to reinforce the conductor. Making it stronger overall and less prone to failure due to the harsh constant flexing a headphone cable receives. The conductors are then surrounded by cotton and then a layer of Teflon tape. This V2 version is now also shielded and placed in a polyethylene jacket for further protection.
For the Black Dragon V2 Premium HD800 version, we are using the Furutech CF-H800 connector. Furutech’s beautifully finished, beautiful sounding CF-H800 connectors are the result of meticulous engineering and careful audition of various suitable materials. The CF-H800 features an α (Alpha) phosphor bronze conductor and Nylon+Fiberglass 15% insulation for minimal impedance and a nonmagnetic stainless and carbon fiber finished main body and nonmagnetic stainless end ring for superior damping. The Pins are Nonmagnetic Rhodium-plated α (Alpha) Phosphor bronze conductors.
The wire is soldered to the connector with high quality silver solder. The default 1/4" Plug is the new Furutech CF-763. Furutech’s beautifully finished, beautiful sounding CF-763 connectors are the result of meticulous engineering and careful audition of various suitable materials. The CF-763 features an Nonmagnetic Rhodium-plated α (Alpha) phosphor bronze conductor and Fluoropolymer insulation for minimal impedance and a nonmagnetic stainless and carbon fiber finished housing for superior damping.
Asking price includes PayPal fees and USPS lower 48 shipping
Length = 5 feet
New $415
