Monoprice Monolith M1060 and M560 Planar Headphones
Discussion in 'Headphones (full-size)' started by wordfool, Sep 13, 2016.
518 519 520 521 522 523 524 525 526 527
529
  1. sman789
    Place the pin with the yoke's inside hugging your worktable edge. Now go to town on the yoke. Two or three big hits should do it.
  2. Deanorep
    Thanks for the reply. I'll try this tonight.
    sman789 likes this.
  3. NiTROAUDiO
    Hey there guys. I'm new here and I just bought a used pair of 1060s for $106 and after hours of research and thread surfing I am buying and nodding these with parts from drschnick and I need help. I gotta get a cable but I want to make my high end one that looks cool because I can't afford $65-150 for a cable. How would I go about this. I just need help picking out wire and connectors. I am a experienced user with soldering and electronics. Also would like to know if buying the nautilus grille, with the baffled fazor and then some fine tune material and dynamay is what I need.
  4. NiTROAUDiO
    I also just got accepted to buy a pair of m560 in mint condition for $75. Is that a good deal ? And what pads and mods can I do for those ?
  5. jotaku
    For custom cables, most people get an XLR cable and braid the cores and sleeve them with the fabric from paracord. As far as connectors, 2.5mm mono plugs like these (https://www.amazon.com/CESS-2-5mm-Solder-Audio-Connector/dp/B01G0NEUMY/) for plugging into the headphones if it is a V2. if it is a V1 then you need MMCX connectors like these (https://www.aliexpress.com/item/33024635522.html). As far as the other end we would need to know if you want balanced XLR or 3.5mm or 2.5mm balanced.
    I've never done the dynamat, but I did do fazors and fuzors. Pads and changing/removing the foam grill side are the biggest differences as far as mods are concerned in my opinion. Fuzors helps tame the transience and peaks in the highs. Fazors help the transience in the FR as well.
  6. jotaku
    I would recommend ZMFs pads. Which pad depends on your preferred sound signature. But the ZMF pads will add comfort and soundstage regardless of what pad you choose. Brainwavz round pads are a good budget alternative. A lot of people go with the Sony MDR-XB500 pads, but I feel these muddy up the sound. IDK about other mods.
  7. Toastybob
    Does anyone know if the M560 can be run balanced with a cable like the following?
    US $15.30 15%OFF | Audiocrast 2.5mm 8core Silver Plated Headphone Upgrade Cable for HE1000 HE400S HE560 Oppo PM-1 PM-2
    https://s.click.aliexpress.com/e/oyuccRwC
    The cable has an option for 3.5mm to 2.5mm, which I hope corresponds to dual 3.5mm connectors to a single 2.5mm. How many poles should the dual 3.5mm ends have? This cable shows TR ends in the photos, but the stock 3.5mm cable is TRS.
  8. TheHeedHunter
    I thought M560 had 2,5mm monos on the cups like M1060 -series? And the cable manufacturer are defitinely referring to 2,5mm mono for headphones and 3,5mm single ended. If the M560 had same 2,5mm mono on the earcups, then 2,5mm to 2,5mm would be the cable to get for 2,5mm balanced on your DAC/AMP.
    Toastybob likes this.
  9. Toastybob
    Thanks for the reply. Unfortunately, my M560 definitely has 3.5mm on the earcups.
  10. TheHeedHunter
    I got the headband ordered to send in Finland, that's a steal even to overseas. Hopefully it will be sent soon.
    OldDude04 likes this.
  11. TheHeedHunter
    [​IMG] [​IMG]
    It's decent. The black vinyl looks like a electrical tape tho. It's much better headband in looks, comfort and not being in a knot if you don't take them off properly.
    theangelboy and trellus like this.
  12. Tony51
    It's beautiful, where did you get the headband?
    Tony
  13. theangelboy
    It's the HE560 V2 headband. This is where people have been buying them. https://www.adorama.com/hmhb560.html
  14. Tony51
    10 dollars for the entire headband? Or is it just for the strap? It has no image.
    Tony
  15. TheHeedHunter
    Whole headband. I got it for 10 bucks plus 57 bucks to ship in Finland. It was cheap still!
529
