I had hifiman he400i and i found them nice but too boring, I'm using now the M1060 v2 which i like more but off course they are not perfect, I'm considering to buy He560 but I'm not sure if they are so much better to make worth the change and i've read that many of them have many issues and not functioning parts
Monoprice Monolith M1060 and M560 Planar Headphones
- Thread starter wordfool
fpantalone
Ahh yes ... the old rabbit hole. There IS no "perfect"
well , perfect in a relative wayAhh yes ... the old rabbit hole. There IS no "perfect"
fpantalone
Kinda like womenwell , perfect in a relative way
OldDude04
Kinda like women
So, beauty is in the ear of the beholder? Lol.
So if I got it right, it seems that if you dont consider top ones, all the others are more or less at the same level and the ones "you" like, they are the right ones.
Maybe to mod my M1060 could be an option, altough is not easy to get the 3D paint parts ,while i wonder which pads could be the right one, considering that it's impossible now to find Audeze alcantara ones
bjaardker
- Nov 11, 2009
Honestly it's super easy to get the 3d printed parts. First option is to message @SomeTechNoob here. Or, if you prefer, go to the links he's so graciously listed in his profile and download the plans from thingiverse. Then just go to 3dhubs.com, upload the plans for the parts you want, and follow the instructions. I just ordered grills for my M1060c in gold for $8 a piece shipped.
hyperactiveaudiophile
$16 to change the grills is very reasonable price.
Wow thank you I'm going to order them for sure and about pads? I've read many options but some are just too expensive compared to the m1060 price
thank you!
theangelboy
And 100% worth it! It does only good things to the sound.$16 to change the grills is very reasonable price.
bjaardker
- Nov 11, 2009
TBH I love the stock pads. I've never had to deal with the ringing issue some people hear so I've just stuck with what works. IMHO the grills are the only mod I've heard that make a really huge difference. The rest is small tweaking.
Architeuthis
- Jan 27, 2010
What improvements will different grills provide for an M1060 without ringing issues?TBH I love the stock pads. I've never had to deal with the ringing issue some people hear so I've just stuck with what works. IMHO the grills are the only mod I've heard that make a really huge difference. The rest is small tweaking.
There are definitely variations in drivers. My original M1060 was brighter and had the ringing issue.
Replacement pair is darker and no ringing.
PockyG
From my experience, a wider soundstage is the most notable difference when removing or replacing the stock grill.What improvements will different grills provide for an M1060 without ringing issues?
fpantalone
with or without the paper towel mod ??
