HI- new member here looking for a little advice. I've just started dipping my toe in the waters of better quality headphones and in November purchased a pair of the M560's from someone locally on Craigslist. They were great for a few months then recently I've noticed the right channel seems to be going out. It's significantly lower in volume than the left. I tried with a few different setups and all the same. I was hoping that Monoprice might replace them since they do carry a 5-year warranty, even though I'm not the original purchaser, but that has proven to be nearly a dead end. I have contacted them 4 times over the past 4 weeks with no replies. Basically I want to know, am I SOL with these and I just need to toss them or is it worth trying to have them repaired? I only spent $100 on them so spending any more than maybe $50 on a repair seems questionable. Any suggestions for possibly escalating my return inquiry to get a reply? Any info here would be appreciated. Thanks for reading.
Monoprice Monolith M1060 and M560 Planar Headphones
- Thread starter wordfool
Shroomalistic
If you decide to ditch them let me know, I’ll buy them off ya and keep them for parts if something ever go wrong with mine.
This might sound shady but you could by a pair from Monoprice and return your old pair and get your money back. I don’t think they honor there warranty once it has changed ownership
SamBBMe
- Nov 2, 2014
Have you tried a new cable? Also, use their live chat -- you're garunteed a response that way.
OldDude04
That don't sound shady, it is shady. Just saying.
I haven't but that's a good idea.Have you tried a new cable? Also, use their live chat -- you're garunteed a response that way.
anyone tried the zmf lambskins. want more bass
just got an xduuo xd05 goes great with the 1060s
Just received those beautiful hand-made pads for my M1060 headphones. They are really high quality and customisable. I went for perforated leather for the inner part of the pad, top is alcantara and outside is black leather. Padding is memory foam. Seller @Vesperaudio is very polite and can provide needed support, recommended and will order again!
rgmffn
- Jul 15, 2015
And they look dope.These have hope
Soundofmusic
- Nov 1, 2010
I just noticed my M1060's (rev 2) have cracks on all sides of the hinges. Anyone know Monoprice's policy on RMA's on items bought through JetCarrier?
nereus
- Dec 1, 2014
How much did those vesper earpads set you back? I've been interested in a pair for another set of cans but those M1060 one look great too.
Base price was 65 USD, but I asked for perforated leather and memory foam which added 6 USD extra.
lentoviolento
- Feb 17, 2017
What do they add to the sound?
Perforated surface should reduce reflections to my understanding. Difficult to compare these and original pads since cavity sizes are quite different. Also original pads had very thick acoustic material covering driver while these pads had very thin. I've added a layer of thick cloth onto fazor to replicate original cover. What I have noticed was added sub bass, probably due to the greater contact point. Should do A/B test for more in-depth insights. I bought these to increase comfort and it paid up well
Total: 6 (members: 0, guests: 6)
