SonnyMarrow
- Dec 4, 2016
I just acquired a Liquid Platinum and am having an interesting issue. The amp will only work if the case is off and there's no pressure on the XLR output port. If I take the case off, I can trigger the protection relay (white to red light) by pressing on the port. I can't seem to figure out exactly what's happening because it's inconsistent. Sometimes I need to push the port to trigger the relay back to white. Nothing obvious is wrong with the port.
EDIT: I've narrowed down the problem to the relay next to the XLR port. If I barely touch the case, it triggers. Should I replace this relay?
