Pharmaboy
I could be wrong about this, but I read somewhere (not here) about the LGX having peculiar problems only when one uses the DAC & internal amp. Problems having to do with intermittent shutdowns. If I recall properly, these same users had no such problem when they used an external DAC plugged into the LGX (as I do).Thanks for the answer:
I am using the XLR balanced output, with the high gain on and with the goldX's own DAC.
It is true that I equalize the bass a little bit, but it gives me the same problem without equalizing.
The thing is that I am a happy owner also of the monollith liquid platinum and although this one also turns me off if I go over volume, but it is not comparable to how the gold X does it, the LCD-2 fail to show the full impact of their great bass. I think it falls short of volume if you are a basshead. It's a shame because I think it's a great amp, but the fact that it turns off is desperate, I think it's an unforgivable failure. They have left the volume limit very low in my opinion........it is unbelievable this blockade with the power that goldX have.
FWIW, I have a planar that's a way worse power hog than yours (ZMF Ori), and my LGX, with Audio GD DAC-19 as the DAC, drives it beautifully...I can barely get the volume dial beyond 11AM. And this is on low gain. I can't use high gain at all with any headphone--way too much volume.
