Monolith M300 In Ear Planar Earphones
Jul 14, 2018 at 12:15 PM Post #481 of 659
Ear Hook links:
Here are links to the ear hooks that a group of us are using. The ear hooks all seem to be coming out of the same factory in China and sold online by several different retailers. The ear hooks work quite well and are very inexpensive. The problem of course is finding horse shoe clips that fit the M300s. That's why we are still making clips on our 3-D printer for m300 and iSine headfiers. The mm size doesn't matter because you are going to discard their clip and replace with ones you make yourself or get from us:
Here are the ear hooks on Amazon you will need to buy:
https://www.amazon.com/PL-Samsung-W...531025807&sr=8-72&keywords=bluetooth+ear+hook
And same ear hooks here on Aliexpress:
https://www.aliexpress.com/item/5mm...396.html?spm=a2g0s.9042311.0.0.27424c4dCGcqHJ
And same again here on ebay:
https://www.ebay.com/itm/lot-5-10Pa...var=441361100816&_trksid=p2060353.m1438.l2649
Here's a thinner clear set as another option. One of our fellow headfiers prefers this thinner clear one over the black ones. He sent me a set and I am going to try them and compare:
https://www.aliexpress.com/item/10m...1359-4a4c-a5e6-610d6677d5d7&priceBeautifyAB=0
Hope this helps.
Frank88
Jul 24, 2018 at 12:55 PM Post #482 of 659
Thanks to the recommendations in this thread, I received the Audeze "groove kit" yesterday. The Audeze iSine hooks are thinner & more flexible than the Monoprice stock hooks, but don't break when you flex them to fit over your ear. They don't pinch either. They've taken the M300 to "wearable for a while", to "disappeared on my head".
Jul 24, 2018 at 9:59 PM Post #483 of 659
Wait a minute. You got the iSine hooks to fit on the m300? The pair I tried broke trying to put it on, as the m300 has a slightly wider area
Jul 24, 2018 at 11:47 PM Post #484 of 659
@Devodonaldson I am using iSine ear hooks on the M300, and while I was afraid they would break as it took some work to fit them, they did fit with some careful force, and they’ve been much more reliable than the original M300 hooks I had, one of which snapped almost immediately out of the box.
Jul 25, 2018 at 7:58 AM Post #486 of 659
Jul 25, 2018 at 9:11 AM Post #487 of 659
Black iSine "Groovy" vs. Clear M300
Jul 25, 2018 at 12:31 PM Post #488 of 659
Guys save yourselves on the hooks. If in the US go to Dollar tree and buy a cheap crappy plastic on ear, rip out the drivers, also buy a hook and loop Velcro square set will run you about 2 dollars all together. Place one side over the speaker grill and the other leave the paper backing on and just cut a small square in the center out of the paper to expose the adhesive. Place that one over the monoprice logo and attach to the cheap on ear headset. Support for the heavy monoprice in ears is sufficent and comfort is much better. No more ear pain to endure. No vents are covered so no sound quality loss occurs.
Jul 29, 2018 at 2:09 PM Post #489 of 659
Can you post a picture of the end result? I'm having trouble picturing what it'll look like when completed.
Sep 30, 2018 at 3:29 PM Post #495 of 659
Any one have anything new about the M300 iem’s?
