Monolith M300 In Ear Planar Earphones
post-13928584
Post #391 of 647
Frank88
Calgary
Calgary
Here's the pics of the 3-D printed ear clips for M300. These are in blue PLA which shows up nicely in pictures. We have since re-printed in black with finer print setting making them a little smoother.
post-13931806
Post #392 of 647
Fra D
That's awesome, wish you would sell those, in black...
post-13932289
Post #393 of 647
Frank88
Calgary
Calgary
Thanks. Hmm. Wonder how much interest there would be. These are just a prototype. To sell them, they would need to be injection molded. There would have to be enough interest to cover the cost of the die. I suppose the way to do it would be to make clips for both iSines and M300s. However, everyone's ear's are different and the angle might need slight tweaking to get the ear canal placement just right. Maybe that's why the manufacturers haven't put much effort into their clips.
I sent a set to a fellow Head-Fier. Waiting to hear his thoughts on the fit.
post-13933149
Post #394 of 647
Ynot1
USA, Cook County
USA, Cook County
I noticed the newer snake cameras have cables that are firm and shapeable. Therefore the cable holds up the camera in many unique shape and position.
I wonder if something like that can be used here.
post-13934053
Post #395 of 647
timb5881
So, what is the final consensus on the M300 iem from Monoprice? Worth getting? Pass?
post-13934663
Post #396 of 647
youngarthur
N/E Scotland
N/E Scotland
Age
80
For me?. Well worth getting. My iSINE 20, and M300 compliment each other, the downfall on both, being the clips. Had done some mods, with a headband, but am going to try something else very soon.
post-13935252
Post #398 of 647
timb5881
So I ordered a pair of refurbished ones today, $99 Plus a 15% discount for a final price of $85 plus shipping. I also ordered a pair of Monoprice beryllium IEM phones($19.99 Plus 15% off them as well). So if they still have some refurbished M300, you can get them for $85 if you use the enjoy discount code.
Reactions: trellus
post-13936659
Post #399 of 647
timb5881
2 cents worth 5 minute job, will last forever...
So what are you useing for wire? I would assume that a couple of layers of heat shrink tube might also work for softening the wire for comfort.
post-13937345
Post #400 of 647
Fra D
That's pvc coated garden fence wire mesh
The silicone wire hooks came with a cheap Penon Audio balanced cable off Ebay. Those hooks are on AliExpress also. Congrats on your purchase, $85 is a steal.
post-13939040
Post #401 of 647
Frank88
Calgary
Calgary
$85? I don't normally buy refurbs but you can't go wrong at that price (provided you recognize the ear clip problem). Thanks for the post. I am going to order another set and give them as a gift.
post-13941601
Post #402 of 647
emusic13
Possible to wear over ear and upside down without earhooks? Or are the nozzles angled
post-13941861
Post #403 of 647
youngarthur
N/E Scotland
N/E Scotland
Age
80
I think I poster a photo of me, wearing them upside down, it worked, but not a final solution.The nozzle angle,is around 15deg, and is less than the iSINE. I have tried headband mod, works, but not ideal, and am waiting for the postman to deliver a solution, which I hope will solve the problem for both the iSINE, and the M300. I have high hopes.
post-13951406
Post #404 of 647
timb5881
Got mine yesterday. Initial listening is positive. I am guessing they may already be seated in as they are a refurbish/open box. Surprisingly the clear hooks are comfortable, I am going to try the ear lock ones and see how they work out.
post-13961907
Post #405 of 647
timb5881
Has anyone had any success in using the earlocks? I finally figured them out, they work good, I am just worried they might slip out. As of yet they have stayed secured.
