Modified Sony MDR-ZX100
SeEnCreaTive
- Oct 6, 2014
- Messages
- 584
- Reaction score
- 161
You really aren't going to get a better headphone for $8
Its just unfortunate Sony made all their low end stuff bass heavy (mod bass with the 100s) but of course that's what people who know nothing about headphones look for. I have a pair of 300s, much more clear, sameish sound, but instead of huge mid bass peak, its much lower in the range, it actually does have some sub-bass
They try my T50RPs and say "these suck, where's the bass" even though they are slightly bass heavy
Nec3
- Mar 29, 2013
- Messages
- 1,634
- Reaction score
- 266
Well I got a better headphone with $30 earpads and $8 headphones
If I recall, speakers only get so good as the room acoustics; same can be applied to headphones too. So I thought, "hey I have all these earpads lying around, why not just try it on the ZX100's". To my surprise it somewhat worked, it was a fun experiment.
Sony had a really good formula with their old tech too. I'm not sure how long end the ZX500's are, but they're definitely enjoyable and not too boomy.
I found the stock T50RP's to be a bit bass light too, although I really heard the potential speed they could deliver before I decided to mod them.
SeEnCreaTive
- Oct 6, 2014
- Messages
- 584
- Reaction score
- 161
Well I got a better headphone with $30 earpads and $8 headphones![]()
Mine are very modded. Stock they are bass light, but mods bring that up to flat (meaning reference), or just a slight touch more (like I have mine) or Ermehgerd all DAT rumbly bass
Side note, my little sister came in when I was over there with some sony headphones I've never seen, look at them, they are zx-100s. I try them, and they blew the doors off my 300s. Clear, and WAY more balanced then my old 100s or my very bass heavy 300s (they said balanced sound on the box...heh)
I guess that's why they were on for so cheap, putting them on sale to make room for the new ones.
Jun Raito
- Nov 25, 2012
- Messages
- 39
- Reaction score
- 13
I'm buying shiny one too.....This one is cheap and got better sound compared average in this range of price.
Rather than closing it further, I opened it up. Some isolation issues most likely occurred.
So this is how I mod mine, step by step
1. Peel a layer of protecting foam
2. Here is the driver, by default. (notice a hole near driver's chip)
3. Add two holes on there and there (beware not to hurt driver's membrane inside)
4. This is optional, open it up using 0.8 mm drill. 4 holes in about a circle with 1.75 cm radius.
(Still not the best configuration, but I hope you got the idea
The end product, will got better "clarity" and soundstaging. Still, the sub bass is unheard and a still got compressed mid....Maybe some recabling, new padding, and better driver's hole configuration will make it. But I just too lazy to prying it further
* This is how the pad removed, for anyone who still wonder....
Pull it gently (from inside of the pad).
InternPrimas
- Oct 15, 2016
- Messages
- 18
- Reaction score
- 10
What I did was cut a quarter size hole in the ear pad so it opens up the driver more and it improves the mids and highs (basically better clarity) it still has the nice bass thumpin' sound. But mind you mying are burnt in had these sony mdr-zx100 zx (white) headphones for over 4~5 years. So they got their fair share of play and burnt in quality (the diaphragram driver has been "worn in" naturally from playing bass heavy and rock/metal heavy stuff even played binarual beats and produced music on them so they got good amplifcation of sound enough to almost tear it...) I didn't use a headphone amp. Anyways I recommend cutting a hole on ear pad the size of a quarter to get more clarity out of the drivers. It won't kill the bass.
