Hi ......,
Please see below for additional information on your request.
Yes it is complex. From what I understood from your initial e-mail, the Dnote chip is able to produce sound (at the last moment) from the signal it receives. But IF an analog conversion is still taking place, it's done so only once vs. the traditional (DAC) way via Bluetooth where a DAC is needed to make sound. Even in a "DAC" situation, the signal is only actually converted once as far as I know when talking Bluetooth. The signal bypasses the DAC in the source device b/c at that point there is no need to convert it to analog yet as BT is digital. The signal reaches the speakers and headphones and then the DAC there converts it. Unless I'm wrong, and there are more than one conversions or chances for distortion to be introduced into the signal that I'm not aware of??
There is no traditional DAC in this headphone, the Dnote chipset processes the unmodified digital signal from the source into density controlled pulses which energizes the voice coil creating the analog signal from the driver. The “conversion” takes place at the driver.
Also, you said "The digital pulses generated by the chipset directly excite the voice coil(s) of the driver to move the diaphragm forward and backward to create the sound waves heard by the user. " This actually doesn't sound like a conversion is even happening at all, but more like a new way of producing sound that doesn't involve analog. So I guess the REAL question is, can sound be produced without analog involvement?? It sounds like you're saying yes, but I guess your tech dept would know for sure.
A traditional DAC is not used, so the signal is not in an analog form until you hear the output from the driver. That is why we say the conversion takes place at the driver. You are correct in recognizing that this is a different way of producing sound through the Dnote technology of Trigence.
Thanks,
Kurt
