Mini-Audio portable DAC amplifier
Apr 7, 2007 at 7:02 PM Thread Starter Post #1 of 3
kaushama
Has anyone got this DAC with integrated headphone amplifier made by mini-audio. It uses DA-revevier chip CS8416 and D/A chip CS 45122 (24-192KHz), its a Hi-End level D/A chip. and its also use 2 op AD797 for headphone amplification.
24bit-192KHz sampling rate! Input: Optical or coaxial and there is Headphone output & LINE OUT!!
Power Source:Integrated two 2000mA Li-On Batteries (8.4V) or external power supply with Battery Life: around 10~12 Hours!!
Impressive!!!
Seems to be competing with Headroom MicroDac.
I have already ordered Musiland H-10!! Otherwise I would have certainly given it a go. May be later I audition Musiland.
Apr 8, 2007 at 2:11 AM Post #2 of 3
Apr 8, 2007 at 2:45 AM Post #3 of 3
Yeah You are spot on regarding the comments on the connection options.
If line out gives better SQ, it will be useful for iRiver H120 users as a portable DAC to be used with a better amp. At least it seems to be giving better battery life than Microdac.
