mhcarlos
- Sep 23, 2003
It's my second day with the Ming Da MC 84C07 to drive my K701s (also relatively new, but burned-in for over 120 hours).
The first afternoon of listening when I just unpacked the Ming Da, warmed it up and simply connected my iPod (5th generation) via the Cardas mini-to-mini that I was using with my SR-71.
The sound was quite... different. It seemed fuller and the bass was there. But it's not quite what I expected and I'm not liking it yet. I'm not sure if the amp needs burn-in (I'm honestly not sure if burn-in applies to electronic parts, but I'm relatively a newbie...).
For a quick replacement of the mini-to-mini connection, I dropped by a Radio Shack and picked up an iPod dock line-out cable by Gigaware:
http://www.radioshack.com/product/index.jsp?productId=3839350
It actually improved the sound.
First question: Is this line-out cable actually good enough or should I take the pain of ordering online something better? Like a Sendstation Pocketdock?
Second question: What else do I need to do or to buy to improve my experience with the Ming Da + K701 combination? The following things came to mind but I'm not sure about the relative importance of each:
1. amp burn-in -- Really? Does this make a difference?
2. better line-out -- Again, not sure of this one...
3. DAC -- Is the D10 ok, or should I get a desktop one?
4. upgrade my AACs to Apple Lossless/get a better source
Thanks in advance. Will really appreciate any advice...
