Linyanti
- Sep 8, 2009
I use lots of gaming and other headphones with this amp. They usually have 3.5 mm plugs so I use adapters. I also got different adapters with different impedances to change the sound.
My issue is that sometimes the headphone 3.5 mm plug had to be put in just perfectly or I would hear only the left or only the right channel. I thought that it was the different adapters. I would trust a certain adapter since it would seem to always give me both channels.
But recently, I found that toggling and jostling the switch on the right side of the amp (the "Earphone/Speaker") switch would also correct this problem.
Has anyone else experienced this issue regarding the 3.5 mm jack position and the right and left channel in the headphones?
(Using Mullard EL-84 and Amperex Bugle Boy 12AX7 Short Plate and really like the sound.)
