Hello,
Wiisus, here are some informations about the Mofsets: http://www.diyforums.org/SSMH/SSMHmosfet.php
I also have some questions. First, sorry for my bad english, I hope you can understand me! Then, I tried to search the answers to my questions, I wouldn't find anything, maybe I didn't use the apprpriate word, it's hard to speak about technical things in english for me lol
Si, here are my questions. I'm going to use a blank PCB material for my amp. I received all my stuff, I understand how to mount the major part of the components, but I still have question:
- About the Power jack: there are three pins on it, I don't know how to connect them to the network, I think there must be two wires coming from it, one from the + pin, and one for the ground right? How can I make a difference between the pins (I use the power jack from the BOM)
- About the Input: I'd like to use a 1/4" Jack input, but I don't understand how to soldier it: the Jack has 6 pins, but I only have to soldier two wires from the Jack to the pot, right? How should I solder them?
- About the Output: I also would like to use a 1/4" jack (the same as the input), and I have to soldier three wires to the six pins, which one go where???
- About the LEDs: I would like to put LEDs in my tubes, one in each, they'll be soldered in the same resistor (the one of the BOM), but where should I put the resistor in the network, and how should I solder the LEDs on the resistor?
- I also have a question about the terminal strips: where should they be mounted on the shematic?
That's all... for the moment lol!
Thank you very much for your help
Antoine
