Juaquin
- Nov 20, 2008
You've checked that there is no conductance between the MOSFET tabs and the case, right?
If you're really obsessive compulsive you can check the resistance of various resistors. They won't necessarily be their rated value (because they are now in the circuit), but resistors in the left channel should measure very close to their counterparts in the right channel. This is of course not necessary but it will catch a wrong resistor value or perhaps a bad solder joint.
