Giuss
- Feb 28, 2009
Originally Posted by Kitarist /img/forum/go_quote.gif Is anyone selling kit for these amps? Or is anyone willing to sell source the parts for me and sell to me as a kit ? (I'm from Europe) Thanks!!! |
Originally Posted by Giuss /img/forum/go_quote.gif Do you thin that I can have a better audio quality using this cable instead of the ipod headphone output? Using this cable, I can bypass the ipod internal power amplifier? |
Originally Posted by Giuss /img/forum/go_quote.gif Hello, this is my starving student, it works great |
Originally Posted by getllamasfast /img/forum/go_quote.gif BUT! with pictures this time |
Originally Posted by getllamasfast /img/forum/go_quote.gif I posted a separate thread about this, but I was told I would get more help if I moved it into this thread, so I'm just going to copy and paste it. BUT! with pictures this time This is the_equalizer's 12AU7 version of the SSMH I just finished soldering a starving student and everything looked good, but when I flipped the switch on with no tubes in the mosfets didn't heat up. I thought that maybe it was because I didn't have the tubes in, so I put them in and turned it on, but then the left one flashed a bright orange and I immediately turned off the amp. I've checked all my connections and they seem to be going to the right places. However, I didn't get to check the voltages because in the process of learning how to use my multimeter as a voltmeter, I blew its fuse... Anyway, do you guys have any idea on where to start troubleshooting? Thanks, ~getllamasfast EDIT: I figured out that the flash was the tube heating up, but only one tube heats up. I let it sit for a while and hope that I could at least get one side working, but then the bottom heaters started flashing and then the power leds started flashing. Now neither tube heats up, nor do the mosfets and the leds blink if the tubes are plugged in. If I leave the tubes out, the leds are fine... Here's a youtube video of what happens when I flip the switch. YouTube - Broken Starving Student Hybrid Pictures: (Sorry about the rats nest of wires and solder... 'twas my first time going p2p and I didn't really have a layout plan... |
