might downgrade from d7000 to d2000
May 16, 2009 at 5:30 PM Post #16 of 20
donunus
Originally Posted by lutwey /img/forum/go_quote.gif
i just read a thread that descrie the simmlarities and diffs of the Ds. the thread indicates that they have the same drivers......its just that the d7000 have some component that gives it 11.4% more power or somethin like that.
here you go
http://www.head-fi.org/forums/f4/var...-d7000-410582/
same size drivers but not the same exact driver unlike the d2k and d5k which share exactly the same driver
May 16, 2009 at 6:06 PM Post #17 of 20
Denaturat
Forget the HD600/650 clamping story, I happen to have quite a big head
and never had such an issue with them. Also, modding Denons can add quite a bit of weight, so that decreases their comfort, keep that in mind.
May 16, 2009 at 7:09 PM Post #18 of 20
j2kei
ok wow thanks a lot guys. to answer the plasticy sound i heard about is only from lawton audio's website, it is under the description for the custom wood cups. hearing all these stuff about the d7000 driver and its larger magnet makes the sound so much better than the modded d2000/5000 makes me really reconsider now on the option of downgrading to d2000/5000. as for the somewhat harsh treble sound (sibilance?) found on the denon series, i thought the reason for this was because it was not receiving enough current, can anyone provide some feedback to this? thanks
May 17, 2009 at 4:32 AM Post #19 of 20
K3cT
Well, I can confirm that sibilance is amplification dependent. For example, I've heard an unmodded D2000 in mini-meet and it sounded sibilant out of an iBasso D3 Phyton but much less so out of my Audio-gd Compass. My friend also notices that there's a slight hiss with some tracks out of the D3 but it's absent with the Compass.
As for how far behind the D2000/D5000 is behind the D7000. IIRC HeadphoneAddict mentioned that this markl'd, recabled, woodied D2000 is more or less the same with the D7000 with the modded D2000 having a slight edge in treble extension. Another friend here who have both has a different opinion though. He said that his highly modded D2000 is slightly behind his partially markl'd and rebalanced D7000 but otherwise pretty much at stock condition with the D2000 being the more forward and analytical sibling while the D7000 is warmer and more musical. Interestingly, he claimed that a modded D5000 falls behind the modded D2000.
May 17, 2009 at 4:56 AM Post #20 of 20
theBigD
Its your amp and source that need upgrading. the d7000 needs good powerfull amplification and a good clean dac to sound the best. and the d5000 has boomier bass than d7000 and i imagine d2000 is similar to d5000.
