kindatadpole
- Oct 27, 2016
My current setup at work is PC>Elijah Audio BPM> Microstreamer. The BPM is a usb cable that allows you to power your DAC with external battery power, rather than use the computers USB power. I currently am using the 4XAA battery pack that came with the BPM.
I was curious if I could use a mobile power bank/recharchable battery pack instead of the battery pack provided by Elijah which uses 4XAA disposable batteries. The reason I am looking to switch is because the batteries are bulky and I don't want to have to keep extra batteries on hand.
The pack I am looking at is an amazon basics pack, 10,000mAh. It has 5v/2.4A output. Any thoughts on making the switch? My gut says that switching to an external battery pack with built in charging hardware and components may be noisier than standard batteries.
https://www.amazon.com/AmazonBasics-Portable-Power-Bank-000/dp/B00LRK8JDC
Thanks!
-Scott
Thanks!
-Scott
