Micro iUSB3.0 Impressions Thread
Apr 9, 2022 at 12:16 PM Post #481 of 498
Blaurocking
79111 Germany
Thank you for the answer.
Ipower is 9v/1.5A
allo shanti is 5.2V/3A and/or 5.2V/1.2A (shanti has 2 outputs)
Ipower works great, but maybe is an upgrade possible with an even cleaner psu (shanti, ifi elite or another).
If you say shanti works, then I will testet it.
Im happy with the iusb 3.0. Its really bring the sound to be almost how I dream to be.
Apr 9, 2022 at 12:19 PM Post #482 of 498
littlexx26
Mars
Ipower is 9v/1.5A
oh no I am sorry. it won't work. iusb 3.0 needs 9v psu. your Shanti is 5.2v so won't work.
Apr 9, 2022 at 12:23 PM Post #483 of 498
littlexx26
Mars
Ipower is 9v/1.5A
if you want to upgrade your power supply to iusb3.0, you can try this
https://uptoneaudio.com/products/ultracap-lps-1-2
I am using it and it is way better than ipower
Apr 9, 2022 at 12:32 PM Post #484 of 498
Blaurocking
79111 Germany
Ipower is 9v/1.5A
Im happy with my chain (finally).
I have shanti already. Thats why. But I will keep an eye on the ultra cap.
But if I make an upgrade then the sotm usb.
Apr 9, 2022 at 4:01 PM Post #485 of 498
That's affirmative, iUSB3.0 requires a PSU that outputs 9V. Thanks!
I'm not sure about other PSUs, but iPower Elite even instead of iPower X makes quite the difference on iUSB3.0.
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
Apr 23, 2022 at 5:36 AM Post #490 of 498
Are there any noticeable sound differences between the nano iUSB3.0 and micro iUSB3.0?
Both products affect sound is the same way, but the difference is in which one does more in the sense of audible changes and that's micro iUSB3.0. Hope this helps, thanks!
Jul 4, 2022 at 3:36 AM Post #491 of 498
BattousaiX26
Twiceland
Anyone tried using iusb with ipower elite? :)
Jul 5, 2022 at 5:59 AM Post #494 of 498
How would you compare iPowerX and iPower Elite? Both have the same noise floor according to specs.
iPower Elite has even better components and higher power supply capacitance, so it should make a noticeable change. Hope this helps, thanks!
