*Updated 2/12/13 to remove erroneous NOS labeling/product info. MDHT revised the product page to reflect the changes.
It looks like MHDT has a new tube buffered DAC out called the Steeplechase. There aren't any reviews out, and it's being sold for $843. Thoughts? Anyone own it and want to weigh in?
I'm wondering if it's slotted to sit somewhere between the Havana and the Stockholm V2 sound-wise?
Details from MHDT:
[size=medium]Steeplechase DAC is capable of up to 24bits/192kHz digital signal inputs. .[/size]
[size=medium] [size=medium]The USB input section is in asynchronous operation. [/size][/size]
[size=medium] [size=medium]Total four independent digital inputs; BNC, USB, RCA and Toslink.[/size][/size]
[size=medium] [size=medium]The 4 digital inputs are independent to each other, only one among them will be active and is controlled by the tact switches located in front panel.[/size][/size]
[size=medium] [/size]
[size=medium] [size=x-large]Specifications:[/size][/size]
[size=medium] [size=medium]Digital Receiver CS8416[/size][/size]
[size=medium] [size=medium]D/A converter AK4396[/size][/size]
[size=medium] [size=medium]Frequency response: 20 Hz to 20 kHz (± 2dB)[/size][/size]
[size=medium] [size=medium]Output impedance: 32 ohms[/size][/size]
[size=medium] [size=medium]Output level: 2.8 Vrms[/size][/size]
[size=medium] [size=medium] All inputs support 16/24 bits/ 32 kHz up to 192 kHz[/size][/size]
[size=medium] [size=medium]Dimensions clear (W x D X H) 276 x 150 x 60 mm[/size][/size]
[size=medium] [size=medium]Dimensions w/ socket (W x D X H) 295 x 170 x 60 mm[/size][/size]
[size=medium] [size=medium]Weight 2 kg[/size][/size]
[size=medium]
[/size]
Details from MHDT:
[size=medium]
