meta42 max-out
Oct 2, 2002 at 12:59 AM Thread Starter Post #1 of 11
LTUCCI1924
Its on the way and I should have it in 2 or 3 days. I dont know what the stuff in it is but here it is.
Elna Cerafine 470µF/25v PS caps
AD8620 op amp
Stacked output buffers
Alps Blue 100K ohm potentiometer
Vishay/Dale RN55D resistors
Class A
WIMA box caps
Belden teflon coated 22g wire
Blue LED
What does anybody think about this amp? Please tell me for I know nothing about this stuff.
Oct 2, 2002 at 1:04 AM Post #2 of 11
andrzejpw
May one day invent Bose-cancelling headphones.
basically, that amp equals my amp, except I don't have cerafine caps. Its an awesome amp, the sound stage is huge, and the hi frequency detail and extension are awesome. As soon as I get a digicam, I'll right a full review.
Oct 2, 2002 at 2:30 AM Post #3 of 11
LTUCCI1924
andrzejpw
HI: wow you really have me excited about my amp. Would the cerafine caps make much difference over what you have in your amp? Your amp sounds fantastic. If you ever have the time could you tell me what all this stuff means or does in the amp. I think the AD8620 op amp is a good one from what I have read but I really don't know anything about all this stuff but would like to know what each thing does and what grade it is and how each thing functions in the amp. Thank you for your replay. I cant wait till I get this amp.
PS
I am looking forward to your review on your amp.
Oct 2, 2002 at 2:53 AM Post #4 of 11
NeoPoe
hey, im as lost as you are when it comes to amps LTUCCI, andr... if u could send some info my way because im confused
thatd be appreciated
(links work)
Oct 2, 2002 at 3:00 AM Post #5 of 11
martioz
Here you go...
Good caps, but in this case in power supply path, may or may not improve the sound over non-cerafine. basically capacitance (larger - better) and dI/dT (higher - better) are important. Responsible for delivering juice to the amp during high current demand like drum passage).
AD8620 op amp
Good op amp, many people like sound coming from it
The heart of the amp.
You got two off each, piggy back, improve current capacity delivered to the headphone and lower impedance.
sorter battery life
Top pot, value (100k is the upper limit IMO) and configuration (shunt, rheostat, etc) is important,
thermal stability is important
Class A
Do search over the internet, basically biasing of the op amps
WIMA box caps
one of the most important part of the amp, large enough to allow low freq to go through, only foil or paper (mica too)
thinner better for input, PTFE best isolating material, <1% sound influence
Blue LED
only esthetic value, try UV led and UV reactive paint in a transparent case
Oct 2, 2002 at 4:10 AM Post #7 of 11
LTUCCI1924
martioz
Thank You so very much for the info on the makeup of the amp. I have a better understand of what all the parts are and do and their value. Thanks for taking the time to respond and explain my non knowledge of this issue. I because of you am a little bit more informed. Thanks again.
Oct 2, 2002 at 4:25 AM Post #8 of 11
LTUCCI1924
JMT
Thank You for the info on the class A explanation. Also thank you for the very speedy service and quickness of building me an amp. I was amazed to hear that the amp was built and sent to me today. I estimate it took about 4 days on your return to do this and I am very grateful to have been able to deal with you. Thanks again.
Oct 2, 2002 at 4:42 AM Post #9 of 11
eric343
Member of the Trade: Audiogeek: The "E" in META42
Cerafines and stacked output buffers - I swear by 'em. But *let the amp burn in*!!! Believe me, the META42 changes quite a bit with some burn-in...
