META vs. Cosmic
post-152153
Post #31 of 36
Audio-Me
Hey, I was just using it as an example, proof that it can sound good with crappy recordings as well. Yes I did listen to your Mahler, it's a good disc to test decay and tone, but overall I like to use my Beethoven 6th and Brahms trio as my test material.
post-152163
Post #32 of 36
tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
Wouldn't you change both the inner and outer loop resistors?
Absolutely not! Changing the inner loop would have very little effect on overall gain, and it would shift the bandwidth of the op-amp with each switch. Since you're only interested in gain, only the outside loop ratio must be changed.
We should take this discussion to the DIY forum if you have more questions.
post-152226
Post #33 of 36
morsel
Hi Geom, I have just discovered Hedningarna, a wonderful Swedish/Finnish progressive folk rock techno world beat sort of group that uses highly unusual instruments ranging from digeridoo to Swedish bagpipes. If you have not heard it, listen to their album Kaksi. Great stuff!
post-152260
Post #34 of 36
geom_tol
Morsel:
I like Hedningarna alot. I've got Kaksi and some other records from them.
Other great Swedish/Finnish bands that play that type of music is Garmarna and Varttina.
This type of music makes you want to jump up and dance.
Not good when you've got headphones on.
post-152324
Post #35 of 36
Nezer
Antibacterial soap... kills bacteria... bad karma?
Originally posted by tangent
For 2 levels of gain, it's pretty inexpensive and straightforward: a DPDT switch, four resistors, and six wires. This is only about $5 in parts.
For 3 levels, you need a DP3T switch, six resistors and 8 wires. Parts are more like $20, and it might be difficult to solder 3 wires into one hole on the circuit board.
It would be better if the board had this feature on it, like Headroom's circuit boards undoubtedly do. I can't say I regret its lack, though.
Who needs a stinkin' switch? Socket the gain resistors and switch as needed.
post-154387
Post #36 of 36
eric343
Member of the Trade: Audiogeek: The "E" in META42
However, one clear advantage of the Cosmic is the nicer enclosure -- DIY efforts just can't achieve that kind of appearance.
Do I smell a challenge?
